How do I select ASIO drivers?
HAMERMAN409
Post by HAMERMAN409 »
I just installed a PCI-324 sound card and everything seems to be working so far (though the latency is on the high side), the driver shows up as WDM.
I have heard that ASIO is the better way to go. How do I actually go about selecting the ASIO driver?
Smokehouse
Post by Smokehouse »
The drivers for both WDM and ASIO get installed and are available. You select which you will use from within the software that will use them. For me, I use Cakewalk SONAR so I select Options>Audio... and on the Advanced tab there's a place to select from WDM/KS and ASIO.
What software are you using for your audio work?
"I'll try anything twice."
Dell Latitude E6400 w/ WIN XP SP3, ADS Pyro 1394 FireWire
SONAR 8.5, WaveArts TrackPlus & MasterVerb, AutoTune 4.1
MOTU 828 MKIII, MOTU 828mkII, Presonus Digimax LT
HAMERMAN409
I am using Sonar and did not think to look there. For some reason I was thinking you had to select which driver was being used in the XP control panel somewhere.
Jidis
Post by Jidis »
HAMERMAN409,
They (ASIO) are generally used in the audio apps. The OS and most multimedia apps aren't written to use them. Coincidentally, the Cakewalk and Sonic Foundry apps were a couple of the long time "non-ASIO" apps on the PC side, as far as the pro/semi-pro stuff goes. Since a few years back though, pretty much everything supports it. The standard multimedia drivers didn't used to be as thorough either (mainly for stereo i/o with internal clock).
Sorry for the trivia, :lol:
George
