who runs dp5.1 crash free on intel?????
daniel.sneed
Post by daniel.sneed »
A big concern still remains : crashes are motu's fault or Apple's ?
Each one says it' the other's, and we stay cooked.
I did not get to figure this by now.
ljuk06
we need DP5.2
Post by ljuk06 »
After one month of trials ...I've proved and tested everything... well
DP 5.1 without any audio harware works correctly...but when you connect
the firewirwe audio interface It crashh
my set up is: macbookpro intelcore 2ghz +1.5 gb ram+ Ultralite + dp5.1
Macbookpro intel 2ghz+1.5 ram+ultralite+express xt -macPPC dual 1250+2 gb ram +mtp +HD192+2408mk2+NI Komplete3+kore+ivory-dbx-korg-elektron-access+roland+yamaha+waldorf+novation ecccc
XYZ
Post by XYZ »
bjornln wrote:I hope everyone who has problems has set their audio to "Built in" and then Rebuilt all of their I/O Bundles ?
Some people had success with that....
Best
/B
How do you rebuild I/O bundles?
MacPro2.66/3GB/828mk3/Rosetta800/UAD-2Quad/Waves/
ljuk06
Post by ljuk06 »
. Start DP and open your project.
2. Go to Setup>Bundles, and delete everything in the Bundles window. Close the Bundles window.
3. Go to Tracks Overview, and build new audio routings, ie: ins, outs, and busses.
4. Open the Bundles window again and Export your Bundle with a name in a folder: both bundle name and folder name should be easy to remember and easy to locate.
5. Save your project and quit DP.
6. Dump your DP Preferences:
User Library> Preferences> Digital Performer> "preferences"
7. Also, if you have the iSight Audio.plugin, move it to a neutral location or delete it altogether. It is normally found:
Mac HD>Library> Audio>Plugins> HAL>*iSight Audio.plugin*
8. Empty the trash.
9. Shut down the computer.
10. Go do something fun.
11. Boot up again and raise your buffers to 1024.
See if there are any improvements and keep us posted.
(copied by frodo)
bjornln
Post by bjornln »
If you're not familliar with the bundles-architecture, it's probably best to read up on it. Check p. 169, and the rest of chapter 13.
Best
/b
michkhol
Re: we need DP5.2
Post by michkhol »
ljuk06 wrote:After one month of trials ...I've proved and tested everything... well
I've always thought when it comes to a real-time application, hardware is the source of the most of the problems. Chinese manufacturing may introduce some technological "shortcuts" (either inadvertently or not) and it may vary from unit to unit. Of course it is impossible to test every single unit but I think that Apple doesn't have (or doesn't require hard enough) a proper test suite for real-time applications at QA point.
MacPro, 32 GB RAM, Metric Halo ULN8
macOS 13.6.3, DP 11.3
XYZ
Post by XYZ »
Best
/b
Ah, you meant DP bundles--yes I'm familiar with them, but dont' know how to rebuild. Do you mean delete them and re-add them them?
X
bjornln
Post by bjornln »
[/quote]
X[/quote]
yupp.
Best,
/B
daniel.sneed
In bundle window, select and delete your input bundles, output bundles, aux bundles, instruments, MIDI.
In track window, rebuild every thing. Say affect inputs and outputs for each track.
OR
Add ins and outs as needed in each section of bundle window, then re-assign in tracks window.
This is better than jumping right in track window, cause you can choose wich are top-list outputs. They are the ones that you will listen thru when scrubbing or selecting sounbites.
Don't forget to re-assign aux in mixer window, and inputs and outputs in virtual racks if you have any.
Takes some times and attention but can be helpfull.
ljuk06
Post by ljuk06 »
3 pages but nobody run DP5.11 crash FREE on macbookpro intel + firewire audio interface
the story of the bundle it's ok, but it doesn't stop crash
XYZ
Post by XYZ »
I assume you have tried
preferential treatment,
trashing DP prefs,
trashing audiomidisetup prefs
repairing permissions with disk utility,
rebuilding Launch Services Database
4ace
Post by 4ace »
ljuk06 wrote:3 pages but nobody run DP5.11 crash FREE on macbookpro intel + firewire audio interface
Runs Fine for me.......200 stereo tracks(torture test)-- (no plugins).....I'm Happy
daniel.sneed
4ace, glad it works for you.
But what about buffer setting ?
Can you get any work done (tracking) at 256, multilier 1 ?
(Crashing here within 1 minute).
I can get some but only at buffer 1024. Such latency is musicaly unusable for me .
ljuk06
Post by ljuk06 »
Dear 4ace ,
coul you write us your hardware configurations and your :) DP settings please?
ljuk06
Post by ljuk06 »
Dear xyz.
I've tried all..i've also completely inizialize the macbookpro twice - tested the ultralite on my g4 dual1250 - tested the macbookpro by the official dealer... I don't know what to think...
