For Logic 7.2 Users ONLY! Anybody hear any Word on MOTU's AU Validation Fix Progress???
I'm not holding my breath, but I'm a new MOTU user & still hopeful!?!
Basil
Any Word on MOTU's AU Validation Fix Progress???
I'm sorry, I forgot not everybody can read minds. Doh!!!
This problem only affects Logic 7.2 users. Whenever a Logic user adds a new Audio Units plug-in, the AU Validation tool (Audio Units Validation Tool), goes through it's paces checking to make sure all the AU Plug-ins are valid. If one doesn't pass validation, you have the option of checking the box next to it anyways and using the plug-in with a warning that it might crash you system and you could lose valuable data, or unchecking the box and not using the plug-in at all.
Apparently, this is a "known issue" to MOTU, which they state on their website in Tech Support, that they are "working on it", but I haven't heard any more about it. Just wondering if anyone else here had a clue? That's all! Thanks!
Peace, Love & Music!
fungk1
Mac G5 Dual 2.3GHz w/4GB of RAM, running Mac OS X 10.4.8 and Logic Pro 7.2.3
fungk1
There was something going on with DP 4.x, but I've been searching for info with this on their site regarding DP 5.1 with no luck so far.
I did have one issue where a failed AU would shut down DP 5.1 entirely, but removing all third-party AUs and trashing the Audio Unit Info Cache fixed the problem.
I then reinstalled one AU at a time, trashing the AU Info Cache file to start a new AU test until I found the culprit.
As it turned out, that particular version of the AU had to be updated to either a later build for PPC or to UB, depending on the plugin.
The solution was easy to find, but I do wish that DPs AU validation wouldn't totally shut down the app.
In one case, I had to start Logic to get the AU validated. That was what totally ironed out the problem. After that, everything passed with flying colors in DP.
Note: any of MOTUs VIs which run in both MAS and AU will be automatically skipped during the AU exam-- and the MAS version will always be used when booting DP. I thought this was a problem, but I learned this is natural-- even if MOTU didn't explain it clearly.
Thank goodness for workarounds.
To answer your question more directly, DP is still on 5.1. Since we've yet to see 5.12 or later, I would say that the problem is not solved. But the workarounds have made a patch for this issue *a little* less urgent than they once were.
