8 ch's of analog->ADAT->analog w/828?
jstaczek
Post by jstaczek »
It seems like it ought to be possible to route the 828's 8 analog ins to ADAT 1-8 out, and then route ADAT 1-8 in to 1-8 analog out. But after futzing with CueMix for a while, it's either impossible, or I can't figure it out. Best I can get is four in/four out, like this:
Mix 1: analog 1 2 panned L R, output = ADAT 1-2
Mix 2: analog 3 4 panned L R, output = ADAT 3-4
Mix 3: ADAT 1 2 panned L R, output = Analog 1-2
Mix 4: ADAT 3 4 panned L R, output = Analog 3-4
Am I missing something? Anyway to route an input directly to an output?
Thanks,
Jason Staczek
www.chromasound.net
Dual 2.5G G5, 6.5G RAM, DP 5.13, OS 10.4.11
MBP 17", 3G RAM, DP 5.13, OS 10.4.11
Pro Tools HD2 Accel, 828mkII, FastLane, Logic 8
gameu
Post by gameu »
You can create 2 different mix presets and swap between them:
Mix 1:
Bus 1: analog in 1-2 to Adat out 1-2
Bus 2: analog in 3-4 to Adat out 3-4
Bus 3: analog in 5-6 to Adat out 5-6
Bus 4: analog in 7-8 to Adat out 7-8
Mix 2:
Bus 1: Adat in 1-2 to analog out 1-2
Bus 2: Adat in 3-4 to analog out 3-4
Bus 3: Adat in 5-6 to analog out 5-6
Bus 4: Adat in 7-8 to analog out 7-8
but you won't get both at the same time, unlesss you make your routing in your audio sequencer.
