Defragment Hard Disk?
- tommymandel
In the old days of OS 9 and earlier, I'd use Nortons Speed Disk Utility to defrag my hard disks as a matter of habit, once every few months if I'd been writing a lot of sound files to my hard disks.
Then others started using Alsoft's DiskWarrior, and MicroMat's TechTool. I'd hear both praise and horror stories about them, and eventually Nortons fell out of favor with the word-of-mouth circles I listened in on.
Now we're well into OSX, with a new cat (10.5) on the horizon, and my question here, to all learned Unicornation Bro's is:
Do you defrag? What do you use? Is it totally safe?
I know that when I install certain software, "System Optimization" occurs- but I am guessing that that refers to defragmenting just the System Files. Am I correct? All opinions appreciated. Thanks!
PS. My question is for a PB Ti running 10.3.9 and a G5 DC2.3 running the latest Tiger 10.4.8.
- Tritonemusic
Re: Defragment Hard Disk?
I'm using Drive Genius for defrag. It does a whole lot of other things, as well. I think it's a great product and have never had a problem with it.
Some people will say this is unnecessary for OS X. Personally, I think it's a very good thing to do periodically. You don't have to do this very often. I know Magic Dave used TechTool to defrag his Powerbook because it was so slow that he could barely get it to run DP. He said the difference in performance was quite dramatic, as far as I can recall. I'm not sure if that post is still in the archives.
As far as your question, "Is it totally safe?": Nothing is totally safe and you should back up everything before doing something like that. Especially, if you count on your stuff to make a living.
Well, that's just my point of view, FWIW.
- Timeline
Hi.
I defrag with the latest version of Tech Tool 4 and fix drives with Disk Warrior first.
Never had a problem but MAKE SURE you have their latest drivers before you do it or you could have issues.
Usually a placard pops up saying something like This version of OSX has not been tested.
I think defrag on a by monthly basis is good but backup is always the best bet considering the horrers we went through with the old os9 utilities like •••• Norton.
- adriano
You might want to try iDefrag. I have not had a problem with it at all.
I usually run Disk Warrior and use iDefrag every couple of months.
Here is a link for it for you to check out.
http://www.coriolis-systems.com/iDefrag.php
Hope that helps and as 666 said nothing is safe.
good luck
good luck
iMac9,1, 3.06GHz Intel Core 2 Duo, 8GB-RAM, 10.9.5
DP 8.07, 828MKIII, Keys-Fantom X8, XV-88. Key
SampleTank v2.5.4, Miroslav Philharmonik v1.1.2, SampleMoog v1.02, SampleTron v1.02, Sonik Synth 2 v2.1.1, Independence Pro v3.2.0126, EZDrummer 1.4, MDrummer Large 5.02, Komplete U9, Orchestral Essential 1, Orchestral Essential 2, Complete Orchestral Collection
Music is the wine that fills the cup of silence.
- adriano
Timeline beat me to it
ouch
ouch
I have used Defrag and recomand it !!!adriano wrote:You might want to try iDefrag. I have not had a problem with it at all.
good luck
Aramis
iMac 2012 27 ' 3.2 ghz 32 gigs ram OSX 10.9.4 DigitalPerformer 8.7 , MOTU Track 16, MOTU MachFive3.2, Ethno and BPM , Komplete 9, OmniSphere , Trilian and Stylus RMX , Axon mkII and Godin LG .
- tommymandel
Thanks everyone. I just bought iDefrag (it was only $30USD), and as soon as I can back-up everything, I will try it out. I didn't completely understand the analysis it made of my PB hard drive - on one level it seemed to be telling me it wasn't fragmented at all, and yet one dv project file was in 1,296 pieces! gotta go read the manual.
Thanks again.
Thanks again.
- adriano
tommymandel make sure you download the coriolis diskmaker (free) to make a boot disk.
- tommymandel
thanks adriano, i did, but i'm not sure if this will include a system, to make it bootable. ciao
EDIT:
ah, i see, it's grabbing boot files off of the Internet. thanks again.
EDIT:
- adriano
Glad to help
You're good to go.
You're good to go.
I don't defrag on OS X.
OS X defrags files smaller than 20MB by itself.
An excellent article with all the technical details about file fragmentation on HFS+ volumes can be found here.
From the article:
Defragmentation on HFS+ volumes should not be necessary at
all, or worthwhile, in most cases, because the system seems to
do a very good job of avoiding/countering fragmentation.
It is risky to defragment anyway: What if there's a power glitch?
What if the system crashes? What if the defragmenting tool has a
bug? What if you inadvertently reboot? In some cases, you could
make the situation worse by defragmenting.
Frank
From the article:
Frank
- Tritonemusic
I've read plenty of those articles and all I can say is that I've seen huge improvements on a number of computers after defragging (however, they weren't my computers). I never saw a big improvement on my computer probably because I defrag occasionally and I guess it never had a chance to go south on me. I rely on real-world results and don't tend to believe everything I read. However, I respect your opinion and if it works for you, it works for you.stratology wrote:I don't defrag on OS X.
An excellent article with all the technical details about file fragmentation.....
I really wish that I could find the post by Magic Dave because that was a great example of what a huge difference defragging can make; even in OS X.
