Hi Guys, i'm just looking for advice on running one HD 192 with one machine.. i also have a Pro Tools HD RIG with a Sync I/o and am wondering whether i should use the 424 internal clock, HD internal clock or clock it externally using the Sync I/O clock ?? i'm using the HD192 for stereo 24/96 mixdowns after Pro Tools feeds multiple channels to an analog console, so the two units aren't needing to be in sync for any reason really besides if the Sync I/O may have better clock.. i suppose i can just listen but i'd really appreciate others opinions !
Oh yeah, also seeing i am only using one HD192 would i notice a big difference by using a Big Ben clock as it's master.. or are they generally quite good when only one device is running the show ! ....
cheers
HD192 Clocking
HD192 Clocking
DP 7.12 ~ G5 dual 2.3 / Mac Pro Quad 3/Genelec ~ ProTools HD 7.4 / 8 with 96 i/o's / MOTU 2408 Mk 3 + 1224
- BradLyons
- Primary DAW OS: Windows
The Sync I/O is a product that is certainly needed when timecode is involved, but I don't feel there is anything special about the internal clock. As compared to the MOTU clock, I honestly don't know if it would be an improvement....but if you already own it, why not try it. The best way to test is record a silent track (recording the noise-floor) both with and w/o the clock and analyze the waveform.
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
Brad Lyons
db AUDIO & VIDEO
cheers Brad ! BTW, do you find a noticeable difference by running the Big Ben ? If i had a Big Ben could i use it to clock the MOTU HD192 running on one computer as a mastering machine and on my 3 96 I/O's running from another machine with PT and DP simultaneously ?
cheeErs ml
cheeErs ml
mix mag (www.mixonline.com) did a review of the bigben - in it he was testing a motu hd192 back to back with a rosetta 96, he really seemed to dig the effect teh bigben had on the sound of the hd192 (even over apogee's own rosetta) - i believe he was running just one hd192 however - so i would think it would make a difference even so. you don't have to take my word for it tho, i've never had the "listening test" myself - but it is something that intrigues me a bit (;laurence wrote:cheers Brad ! BTW, do you find a noticeable difference by running the Big Ben ? If i had a Big Ben could i use it to clock the MOTU HD192 running on one computer as a mastering machine and on my 3 96 I/O's running from another machine with PT and DP simultaneously ?
cheeErs ml
anyways the article is here.
http://mixonline.com/products/review/au ... onics_big/
here's a quote to intrigue you
"The sonic differences between recordings made with the HD192 A/Ds when slaved to Big Ben's internal clock vs. using the HD192's internal clock were simply astounding."
