hi all,
i had no problems this morning... everything was working fine... power supply worked and all...
until this evening, i did a version update on my Cuemix. i tried doing a firmware update on my traveler but it said that it didn't need to since mine was updated to the latest 1.05.
all this was done with my traveler drawing power via firewire.
then i wanted to do a factory reset... coz i was having problems with quicktime files giving high pitch beeping sounds.
i plugged in my AC adapter and switched on my traveler... nothing happened! no display nothing!!
panicked!
it still powers up via firewire connection.
the AC adapter works.
has my fuse blown? does the AC share the same fuse as the bus-powered setup?
HELP!!
everything was going fine until... power supply issue!!
