EDIT: SOLVED
It was just a matter of telling MacOs to give access to the "microphone" to DP in the privacy preferences.
DUH
Hi all,
It's been a while since the last time I posted.
All was good until I upgraded from 11.01 to 11.21
Now DP does not receive any audio from my interfaces.
In the Metric Halo management app MIOConsole I create an input track and assign its output to an inter-app bus,
I then select that bus in DP as the input to an audio track
I record arm the track but no activity is shown in the audio monitor window.
Recording confirms that there is no audio passing from the MIOConsole.
To be clear, the same steps work as expected in DP11.01 and other apps such as my Kyma system and Izotope RX.
Is anyone here usinh Metric Halo interfaces and having this kind of behavior with DP11.21?
Using DP11.21 on a 2015 MacPro with OS10.15.7
2x Metric Halo 2882 3d interfaces
[SOLVED] DP 11.21 not receiving audio from Metric Halo MIOConsole
Last edited by Visconte Cobram on Tue Oct 24, 2023 3:13 pm, edited 1 time in total.
Re: DP 11.21 not receiving audio from Metric Halo MIOConsole
Don’t know this issue but 11.22 was a major bug fix. 11.23 was released recently but only addresses a few Sonoma issues.
I would update DP first, then see what happens.
Re: [SOLVED] DP 11.21 not receiving audio from Metric Halo MIOConsole
We all forget that one. Thanks for reporting back.Visconte Cobram wrote: ↑Tue Oct 24, 2023 1:30 am EDIT: SOLVED
DUH
I still recommend updating to 11.22 (or 11.23 if planning an update to Sonoma). Lots of bug fixes from 11.21.
Digital Performer 11.23 Read Me
Thank you for installing Digital Performer 11.23.
Complete DP 11 documentation
You can find complete DP 11 documentation (PDF files) in Digital Performer's Help menu. Table of Contents entries, index entries, and cross references are live links that will jump to their destinations. In some cases, you may need to click directly on the page number (rather than the heading).
Changes and new features
For a comprehensive list of new features, please refer to New Features in Digital Performer 11, available in Digital Performer's Help menu, which provides the page number in the manual for each new feature.
Enhancements introduced in version 11.23
Fixes
• Fixed a bug causing the Mac menu bar to not activate without double-clicking on macOS Sonoma.
• Fixed a bug causing the titlebar height to appear incorrect on certain windows in macOS Sonoma.
• Fixed a menu bar text alignment bug in macOS Sonoma.
Enhancements introduced in version 11.22
Enhancements and optimizations
• Improved the channel assignment mechanism for hardware i/o and instrument side-chains.
Improved the opening speed of QuickScribe with large scores.
Added a Rosetta Mode indicator to the DP splash screen which only displays when running in Rosetta on Apple
Silicon.
Minor optimizations to EUCON communication flow.
Improved compatibility with MIDI files from Cubase.
Removed the "Toggle Full Screen" command from Windows, where it's not applicable.
Fixes
• Fixed a bug causing instrument insert automation parameter names not to display correctly in the Sequence Editor strip menu.
• Fixed a bug that would incorrectly report command binding conflicts for certain MIDI bindings.
• Fixed a bug causing "Open in Finder" not to select the files upon opening a Finder window.
• Fixed a bug causing visual glitches in the MIDI editor on Windows when the window is vertically resized.
• Fixed problems reading project files containing certain chunk lengths that are off by 1.
• Fixed cases where the current controller (MB) state would not be saved before duplicating a Mix Take.
• Fixed a bug causing snapshots to generate extra MIDI data on multiple channels.
• Fixed a bug causing vertical text to be truncated and misaligned on macOS 13+ in places such as the
bundles window and the Change Velocity window.
• Fixed a crash that could occur when using only an ICON Control Extender without a main unit.
• Fixed a bug causing track ordering to get scrambled when reordering groups of tracks from the Tracks
Overview window.
• Fixed a bug causing open effect window positions to migrate down every time the project is saved/
reopened.
• Fixed a bug causing the forward-delete key on Mac to get passed to DP while an OS file dialog is open.
• Fixed a bug causing Windows to import tracks in reverse order when dragging sound files from File
Explorer.
• Fixed a bug causing tooltips to be misaligned on Windows.
• Fixed a visual glitch causing the waveform to flicker when editing with the slip tool.
• Fixed a EUCON bug causing insert and aux controls not to update correctly after using the control surface
to add or edit them.
• Fixed a visual glitch in the mixing board level meters.
• Fixed a slur engraving bug causing slurs to always originate from the first notehead in a group of tied
notes, which could occasionally cause undesirable results.
• Fixed a bug causing the QS alternate measure dropdown box not to respect the page scaling factor, which
could lead to visual glitches when viewing the arranged score at a custom page scale factor.
• Fixed a bug that could cause crescendo/decrescendo hairpins to be repositioned incorrectly when
reinitialized on a grand staff due to a change in line breaking.
• Fixed a bug causing lyric text to be duplicated in MusicXML export.
• Fixed a MusicXML export bug causing chords to duplicate or otherwise export incorrectly on tracks using a
grand staff.
• Fixed a bug causing coda and segno symbols not to function correctly.
• Fixed a bug causing double-repeat barlines not to draw correctly in certain configurations in the arranged
score view.
• Fixed saving VST3 preset data.
• Fixed a bug causing keyboard scrolling shortcuts not to respond in the MIDI editor.
• Fixed a bug causing the Selection Info window to get stuck in a bad state when first opened in a
standalone window.
• Fixed a problem where bundle channels could sometimes slip one notch to the right.
• Fixed a crash that could happen when changing sample rates with the Spectral view showing on
soundbites in the Sequence Editor.
• Fixed a longstanding bug causing soundbite lengths to incorrectly be affected by sample rate changes.
• Fixed a bug causing the Custom Time Formats dropdown not to work correctly.
• Fixed a Windows bug causing the Edit Custom Time Formats dialog to not display the selection highlight
after editing the name of a custom time format.
• Fixed a bug that could cause MIDI files to export incorrectly for tracks containing notes on channels other
than Channel 1.
• Fixed part of the MAS layer for older plug-ins that would cause them to seemingly lose automation during
play selection or BTD.
• Made sure the internal connection between the MIDI half of a combined instrument track stays connected
to the instrument track's VI.
• Worked around a VST3 dead-lock that could occur when starting a gesture. This was happening in certain
UAD plugins.
• Workaround for a macOS bug causing erratic behavior in the Import Audio and Export Selected
Soundbites dialogs on macOS 10.14+.
• Worked around a Ventura bug in Core Audio export.
• Fixed a bug that could cause black windows in DP, and potentially other undefined graphical glitches.
• Worked around a macOS bug that could cause visual glitches and distortion when opening a region op
window.
That issue stymied a lot of us in the beginning! Used to be you didn't get any notification from DP that it needed to be enabled if I recall correctly. Glad you got it worked out.Visconte Cobram wrote: ↑Tue Oct 24, 2023 1:30 am EDIT: SOLVED
DUH
