My 24ai is failing to load past the third cycle of the loading screen. It just freezes and at that point does not respond to front panel buttons or AVB networking. I've disconnected all cables and am plugged to power with a direct cable. If I hold either the SEL or ID buttons before the loader starts, I'm able to access two different firmware update dialog screens.
Does anyone have any experience with this issue or advice for things I could try?
Backstory is that I'm connecting this to a new M2 pro Mac Mini (Ventura). It was working fine after installing the latest drivers and appeared correctly in the Audio/MIDI setup. I ignored it for awhile and started adding extra peripherals to the USB bus and at some point it lost sync/removed itself from the Audio/MIDI setup. I rebooted the 24ai and it was never able to get past the third wave of the loader. My hunch is that it's just gotten stuck in some bios freakout and maybe a firmware update or hard reset might help. At least that's me being optimistic. I saw that there were some special secuirty adjustments that were needed on the M1 processor with certain interfaces but the 24ai wasn't listed (https://motu.com/techsupport/technotes/ ... rm=silicon). I would think that could be an issue except the unit is freezing even with all cables disonnected so at the very least hardware conflicts aren't immediately the problem.
Appreciate any wisdom that might be out there. Thanks in advance.
24ai stuck on loading screen
Re: 24ai stuck on loading screen
I hope you find an answer. I have a 24Ai as well, but haven't had any problems. I daisy chain it off the back of my 828es. I hate to kick the can down the road, but this might be something you would need to contact MOTU about. Not sure if there is a hard reset, or if you can get into the firmware update dialog, updating firmware would be a good idea or not? You'd obviously have to be connected to your Mac via ethernet cable to do a firmware update. I've only updated firmware on mine once if I remember correctly, but I don't remember "two different firmware update dialog screens."
Sounds like time to call the mothership... this board isn't run by MOTU... so might be someone there might have a better answer for you. I don't remember if they still do phone support. Used to be if you got up early and started dialing at 9am EST you could get a tech on the phone who might be able to help. Might just be support tickets now?
Hey James. Thanks for the reply. Turns out it's a power supply failure. I bought the unit second hand and reported the problem to the seller who admitted the same thing had happened some years ago and was repaired under warranty. We'll be working out a return/refund. Posting the outcome here in case anyone comes looking for diagnosis in the future.
For anyone else finding this in a search, there is a factory reset procedure:
https://motu.com/techsupport/technotes/reset
24Ai: Push the ID button on the front panel of the unit. Use the arrow keys to navigate to Settings menu option. Push SEL button. Use the down arrow key to navigate to Factory Defaults. Push SEL button to prompt the reset, push SEL again to perform reset
Thanks Mike!
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.31
