Hi folks, hope someone can help ...
Because of the impossibility of combining separate Vienna Instrument Pro instances onto single a MIR stage within Vienna Ensemble Pro, I have instead frozen reverb-less MIDI files with VI Pro to create audio tracks.
The aim is to combine all of these dry audio tracks on to a single MIR Pro stage within VEP in order to add reverb.
But, it seems, I’m not routing it correctly.
This is what I’ve done:
1. Created a new instance in VEP called ‘MIXING’ and a new instrument track in DP, called the same, and established a connection between the two.
2. Starting with my flute audio track, I have inserted as a plugin ‘VEP Audio Input’ or ‘VEP Audio Input MAS’ (I have tried both) and connected to ‘MIXING’. (As soon as I do this the audio stops playing.)
3. In VEP have added a new input channel called ‘Flute’ with input is ‘IN 1/IN 2’.
Nothing happens!
(I have also tried routing the audio track to a bus and locate the plugins there instead but the result is the same).
What am I doing wrong? Is the whole workflow flawed?!
Any help much appreciated!
DP Audio into VE Pro
