Hello good people and happy new year to all of you.
I was amazed how much of precious time is consumed while setting up a multi timbral instance..
For example if I want to setup a Kontakt instance with 16 instruments, I need to
1 - load Kontakt
2 - Move it to V-Rack
3 - Add in Kontakt 16 empty racks
4 - Go to Kontakt->Outputs->Batch Functions..etc to set all the outputs of each rack
5 - Go to Bundles to assign each instrument
6 - Create 16 MIDI Instruments on Tracks window + Rename AND assign the input/output for every track
7 - Create 16 AUXiliary track (1 for every MIDI track to send it to the Mixer) + Rename and assign
8 - Start loading the VI libraries
9 - While loading meditate in hope that I will not loose the initial idea that made me do all the above.
Is there another quicker workaround?
Like template.. a pre existing setup to load it inside a project.
Surely I wouldn't be the only one with that kind of an issue, thought I could not find anything similar here at the forum.
Thank you in advance for your responses.
Fast multi timbral setup
