MOTU 16A
MOTU 16A
Hi,
Just reading over these associated interfaces with AVB - How long have they been out for? - Will there be a change to MOTU interfaces eg_updating the software in any way or the hardware such as thunderbolt.
The interaces show "Thunderbolt" on a mini_display_port but there is no mention of thunderbolt_2 which would be 20 Gb/s (giga_bits_per_second)_
If these interfaces are thunderbolt eg_version 1 that would limit them to 10 Gb/s which is probably more than enough bandwidth anyway.
I've logged into my account here on a different system as my regular office system wouldn't allow me to log_in stating, "go away spammer" which I am not by the way.
Any info. on these interfaces please mention, thank you.
Re: MOTU 16A
You might get by with 10G. I think it has a practical limit of about 5000 tracks, although in theory it can do more.fraz wrote:If these interfaces are thunderbolt eg_version 1 that would limit them to 10 Gb/s which is probably more than enough bandwidth anyway.
Re: MOTU 16A
The new Fast USB 2 interfaces that began hitting the market around Sept/Oct 2019 all boast near zero latency without such artifices as CueMix etc. As far as I can tell, are all using the same DAC to achieve this sonic milestone. The ones I've tested are extremely fast — far more than my 828mkII sans CueMix.
The fastest Fast USB 2 interface I've found advertises a round trip of 2.43ms on a Mac if drivers are installed @ 32 sample buffer at 96 kHz; 2.96ms with Core Audio. There is one TB3 interface that advertises 1.96ms rt and another that advertises 1.0ms (both with drivers), again @ 96kHz and 32 sample buffer.
To put this into perspective, sound travels at 1.125ms per foot (343 meter/second) from your monitor speaker to your ears. In my case, that's nearly 5ms from my concentric D8 to my ears.
Buffer size, in context, makes an immense difference, BTW.
Re: MOTU 16A
OK, thanks for the wise_crack - more than enough bandwidth.bayswater wrote:You might get by with 10G. I think it has a practical limit of about 5000 tracks, although in theory it can do more.fraz wrote:If these interfaces are thunderbolt eg_version 1 that would limit them to 10 Gb/s which is probably more than enough bandwidth anyway.
I was really looking for more information - So these interfaces are thunderbolt 1 are they?
Do MOTU have any plans to update the software in any way? -(just asking)_about the interfaces / software interface etc..... Thanks
Re: MOTU 16A
Why?Do MOTU have any plans to update the software in any way? -(just asking)_about the interfaces / software interface etc...
The current drivers are Windows 10 and Catalina compatible. Most of the old hardware works with them (if the firmware is new enough) — even though unsupported by MOTU.
Re: MOTU 16A
No one here knows what MOTU's development plans are. The point behind the crack and the other replies is that it doesn't really matter.
Re: MOTU 16A
Indeed, Stoivo.
Fraz, you could run 64 simultaneous ins and outs over USB2 at 1x SR's (44.1 / 48kHz) with the AVB line. So, if USB2 would more than cover your bandwidth requirements, obviously TB would meet the spec many times over.
Re: MOTU 16A
The MOTU site says it does 256 channels, presumably limited by the connections it can make. As you say, even on USB 2 it is likely to do more than mortals or monkeys require. As for whether it's TB 1 or not, since it doesn't say, I suppose it is, but sales@motu.com will have the answer.
Re: MOTU 16A
Right OK it doesn't matter - -fair enough as these are very capable units.
With regard to computers, motherboards, processors, memory, interfaces etc.....the specs and understanding them generally is important and the MOTU units whether thunderbolt 1 or not doesn't matter as the performance envelope is huge anyway with very low latency.
The AVB interfaces connection with RJ45 is great with upgrade easily facilitated for more I/O.
Thanks for the information
