Removing instruments within DP
I am working with NI Kontakt and Reaktor within DP. I have worked with different versions over the years. I still have Kontakt 5 and Reaktor 5 installed on my Mac and they are coming up under 'New Instrument' within DP. I only want to use the latest versions though (Kontakt and Reaktor 6). I don't necessarily want to completely remove the older versions from my Mac because I assume that they will be needed when opening older DP projects that used them or will DP use the latest installed version instead? Either way I don't want them coming up as options for 'New instrument' - I just want the current ones. Any advice?
3.7 GHz Quad-Core Intel Xeon E5 Mac Pro, Mac OS 11.5.2, 64 GB RAM, MOTU 8M, DP 11.01
Re: Removing instruments within DP
Disable the ones you don't use in DP Preferences
... or along similar lines, create a new Plugin set in Preferences and only include the plugins you use regularly in that. If you need to get to the others, you can load the old set.
Great - so simple - thank you to both of you.
- Prime Mover
Easy, record the guitar upside-down, so the waveforms cancel out, right?
— Eric Barker
Eel House
Eel House
I hope you're not poking fun at left handed players, or Australians, or left handed Australians (would a left handed Australian be playing the right way up? Nicky???)Prime Mover wrote:Easy, play the guitar upside-down, that should cancel out the waveform, right?
Hendrix will come to haunt his dreams if he is!bayswater wrote:I hope you're not poking fun at left handed players, or Australians, or left handed Australians (would a left handed Australian be playing the right way up? Nicky???)Prime Mover wrote:Easy, play the guitar upside-down, that should cancel out the waveform, right?
