Preferences window not responding
- Kev
- Primary DAW OS: Windows
When I open the Preferences window for a second time in any session, it won't allow me to select any of the items in the left panel. It justs stays one the one that was selected last time I opened it. I have to close DP and relaunch it to make it work again.
Occasional user of DP(v9.52), Mainly using Cakewalk and Mixbus32C(4.3).
i7-13700|Gig-UD790-RD|UAD2octo+solo|Multiple-drives|MatroxC420|W11
Audient-iD44II+ASP800|Aphex141B|KRK-VXT6|+VariousOutboardGear|+guitars&basses|+MIDI-keyboards
Re: Preferences window not responding
I'd trash the DP plist. Very likely corrupted. Do this with DP not running. You can move the current plist out of its folder to save a copy in case I'm wrong. Second move: reinstall DP if the 1st move doesn't solve this. It probably will.
- Kev
OK, but where is this folder? I searched for a file named "plist" but it doesn't seem to exist.MIDI Life Crisis wrote:I'd trash the DP plist. Very likely corrupted. Do this with DP not running. You can move the current plist out of its folder to save a copy...
I know MLC was trying to be helpful, but "plist" is a Mac file. I don't know where the Windows equivalent would be, but it might be a config file, or worse, some arcane file in the Registry.Kev wrote: OK, but where is this folder? I searched for a file named "plist" but it doesn't seem to exist.
828x MacOS 13.6.7 M1 Studio Max 1TB 64G DP11.31
Oooops. PC? I'm dead in the water. Sorry.
- Kev
I found it! It's called Preferences (no file extension) and it's located within the Users AppData folders. Anyway, I renamed it, launched DP and a new file was automatically created. This seems to have fixed the problem.cuttime wrote:I know MLC was trying to be helpful, but "plist" is a Mac file. I don't know where the Windows equivalent would be, but it might be a config file, or worse, some arcane file in the Registry.Kev wrote: OK, but where is this folder? I searched for a file named "plist" but it doesn't seem to exist.
Thanks to both of you.
De nada! The clue was that the preferences were not being saved. Glad to help.
