I just got DP 9.02 up and running on a new build, with Windows 10 Pro 64bit. I noticed the text looks blurrier now as compared to my older system running Win7. Text everywhere else on the computer looks fine.
Anybody else notice this?
Fuzzy text on Windows 10
- Primary DAW OS: Windows
DP9.5 64bit, Windows 10 Pro 64bit, UA Apollo Quad FireWire interface, Desktop: Intel i7 5820K at 4.0ghz, MSI X99A Gaming 7 mobo, 48gb RAM (DDR4 at 2133 mhz), MSI GTX 960 2GD5T 2GB, 512GB Samsung 950 Pro m.2 SSD (project/system drive). VEP 6
Re: Fuzzy text on Windows 10
I am also experiencing this same issue with my new upgrade to DP 9 on Windows 10 (I came from DP8 on Win 7 where everything was fine). It definitely makes it hard to do extended recording sessions and is starting to give me head aches... This could really kill my productivity and work flow.
Did you ever find a solution?
Here's an example of the Bundle Window in DP next to a pdf of the DP manual (for some reason it is showing a bit "blown up", but you can still see the radical difference):
It turns out that since I am using a high resolution screen, I had the overall screen zoom set to 125%. This was causing DP's text to look "stretched" and fuzzy. Setting it back to 100% in Windows makes the text clear, but extremely small. None of my other native Win programs were negatively affected, but at least we have a way to clear up the fuzzy text.
Looking on the bright side...with it set back to 100%, it makes everything in DP look small, but really makes the visible track count very high!
