How to set a new MIDI track's input default to what I want?
Hi,
if I add a new MIDI track, the input of it always was selected to some source I don't want. Is there a way we can set a new MIDI track's input to what I want by default?
macbook pro 10.10, 2.5G,16G ram,256G SSD
Re: How to set a new MIDI track's input default to what I wa
Please reference the manual for basic information. There are many ways to change and manage tempos. It's just too much for a forum post. The information is all there in the manual.
- Robert Randolph
Either the OP was edited or you are maybe replying to the wrong post?Shooshie wrote:Please reference the manual for basic information. There are many ways to change and manage tempos. It's just too much for a forum post. The information is all there in the manual.
Hey Shooshie,Shooshie wrote:Please reference the manual for basic information. There are many ways to change and manage tempos. It's just too much for a forum post. The information is all there in the manual.
I guess you're right, I found that tempo thing in manual, DP is actualy great to use. tempo post deleted.
For this default intput, I checked again, didn't find it in manual.
Not that I know of, but here's a workaround: Add a MIDI track that will act as a template. Change the input to what you want as the default. Don't record in it, leave it blank. Add a Similar Track by Control-Command clicking the template track. Include the Option key to add multiple Similar Tracks.rockman413 wrote:Hi,
MacBook Pro retina 2015, i7, 16GB, DP 10, M4
Sorry, noticed your on Windows. Make that Alt instead of Option.
Great way!b.g. wrote:Sorry, noticed your on Windows. Make that Alt instead of Option.
Thank you!
If you use Duplicate Tracks, you get all the plugins and plugin settings, too.
Robert Randolph wrote:Either the OP was edited or you are maybe replying to the wrong post?Shooshie wrote:Please reference the manual for basic information. There are many ways to change and manage tempos. It's just too much for a forum post. The information is all there in the manual.
I have no idea. I sure thought I'd replied to the tempo post. Maybe I accidentally closed it while trying to reply. Doesn't matter, though. The intent was clear.
Gears were shifted. Hope the clutch was disengaged.rockman413 wrote:I guess you're right, I found that tempo thing in manual, DP is actualy great to use. tempo post deleted.
As of DP9, use "Create tracks" (ctrl-shift-c on Windows). Here you can set the input and output defaults for as many tracks as you want to add, and have inputs and/or outputs assigned consecutively if so desired.
