Background Processing Fix ?
Maxx
Post by Maxx »
Any idea how to resolve background processing window from opening / running tasks each time A particular DP session is opened? (other sessions are fine)
The background processing runs each time a particular session is opened - even after DP session was saved following completed tasks.
The background processing window lists lots of files : 'BUILDING OVERVIEW for... which takes some time to complete.
The Waveforms are intact.
Any fixes / Suggestions?
M
a
x
OSX 10.7.5 / 2.66 Ghz Intel Core 2 Duo / Motu 8 pre / DP 7.24
Dan Worley
Re: Background Processing Fix ?
Post by Dan Worley »
With the project closed, trash the Analysis Files folder for that project. When you open the project again, the Analysis folder and files will be recreated. That will usually fix it, but not always. Sometimes you have to Load the chunks into another project.
BTW, if you haven't already, take a look at the Background Processing preferences and see if there are any changes you'd like to make for the way you work (DP > Preferences > General > Background Processing). I know for me, I don't need to have the Background Processing window open and close automatically, so I turned that off. I haven't seen the background processing window in years. I made other changes, too, specific to how I work.
DP10.13
fgagne
Post by fgagne »
This is supposedly fixed in 8.07.
I haven't dug in 100% but I'm not convinced it is.
Maxx
Post by Maxx »
Dan Worley wrote:With the project closed, trash the Analysis Files folder for that project. When you open the project again, the Analysis folder and files will be recreated. That will usually fix it, but not always. Sometimes you have to Load the chunks into another project.
Thanks for the suggestion. The first suggestion didn't work but motu tech suggested another one - to load chunks in empty DP session which I haven't tried yet.
In terms of turning off background processing, doesn't DP do the work I set it to do - regardless of whether I see the window or not? By having the background processing window open, I can tell what is happening when things are lagging a bit...
I set up certain analysis tasks useful for what I'm doing like find beats / tempo etc so whether the window pops up to show me or not, it's still going to run.
M
a
x
Maxx
Post by Maxx »
fgagne wrote:This is supposedly fixed in 8.07.
Thanks... Good to know. I'll upgrade once I've completed this project. (I won't upgrade in the midst of a project) I actually did when 8 first came out and was having issues so I'm back in 7.24 :D
M
a
x
