OS 10.9.2 Altered MOTU Audio Setup
After updating to Mac OS 10.9.2, my MOTU Audio Setup lost its Stereo in and out defaults.
Here is the way it used to be before the update:
And now after the update, as you can see, I can no longer access Default Stereo input or output:
I've tried everything, but cannot get the Default Stereo Input or Output to appear any longer.
Re: OS 10.9.2 Altered MOTU Audio Setup
Can you select in Mac Audio Preferences?
You might try deleting the plist for Apple's Audio/MIDI setup and creating a new setup from scratch. Of course after updating the OS repairing permissions is standard.
I just installed the audio drivers on my test partition running 10.9.2. Works fine with my stuff. Other than repairing permissions, try re-installing the audio drivers from the latest download at the MOTU site.
Same missing options here with the 828mkII. Setting the default input and output in AMS has never worked with the MOTU audio interfaces - MOTU Audio Setup has always been the only option here.
Tried other versions of the drivers and still same issue. I do not recommend deleting your MOTU firewire preferences if you are using something other than Main Outs. I use S/PDIF for default stereo/mains and only way to get that set again is to restore preferences from backup. At least the previous settings are sticking and not reverting to defaults.
DP8.06 PT11.2.0 VEP 5.3.x
All good here.
Works with the Mk3.NazRat wrote:Same missing options here with the 828mkII.
- Gravity Jim
Also good here with my Tascam interface. No change.
Jim Bordner
Which has nothing to do with MOTU Audio Setup. Sorry, but I'm getting tired of OS updates breaking things. It appears to be a 828mk2 issue at this point.Gravity Jim wrote:Also good here with my Tascam interface. No change.
- Gravity Jim
Gee, sorry, Naz. I'll be more careful before I comment in the future.
Jim Bordner
FWIW, I'm having the same problem with my 828 original.
iMac Intel Core i5 3.2ghz - 16gb RAM - OSX 10.10.5 - DP 9.01 - Mach Five 3.2.1 - Ethno Instrument 2.0.3 - Kontakt 5.4.3 - 4pre - 828 original - micro express
Same issue here with 828mk2....
10 core iMacPro | 64 GB RAM | OS 12.6.7 | LOGIC PRO | STUDIO ONE 6 | CUBASE 12 | BITWIG 5 | DP 11 | MOTU Interfaces | Waaay Too Many Plug-ins |
http://www.gesslr.com
Same here -- 828mkII.
Mac Studio Max | 32GB | 14.5 | 828es | M4 | DP 10.13 | Studio One 6.6 | Logic 11
Having the same problem - destroys my monitoring setup.
Has anyone submitted a Tech Link?
I see the same window but don't have a problem with it - I think. I won't be able to test it fully until this weekend.
