This happens all the same on Windows 8 and Windows 7, the two oses that I have. Both x86. Both oses work flawlessly for any given amount of time when MOTU is powered off.
Please fix this asap. I can easily help testing if needed. I will be looking on MOTU.com for an update, otherwise.
I'm fairly sure that Adobe Flash is freezing on me due to the same issue, when going full screen, because when it does not freeze the machine completely, it does instead trigger the bsod.
I don't think it matters, but in case it does, were talking about an original Traveler hardware 1.07 boot 1.01 and HIS AGP ATI 3850 Turbo (latest driver which is perfect).
Thanks for the great service in the past with a similar issue. It is always appreciated:
https://rapidshare.com/files/2636540431 ... 812-01.dmp
Code: Select all
STACK_TEXT:
9ff87ba8 8131b600 0000000a 00006664 00000002 nt!KiBugCheck2
9ff87ba8 8e6ee6a9 0000000a 00006664 00000002 nt!KiTrap0E+0x2c8
WARNING: Stack unwind information not available. Following frames may be wrong.
9ff87c3c 8e6ee7bf 838d6610 00000012 838d6610 motufwa+0x326a9
9ff87c54 8e6ee9ab 838d6610 8388b690 9ff87cc8 motufwa+0x327bf
9ff87c64 8e6f20fc 00000005 8e6f4793 8388b7e8 motufwa+0x329ab
9ff87cc8 8e6f25f1 00000000 8388b7e0 00000000 motufwa+0x360fc
9ff87d04 8e6f260c 838d69e0 8e6ee54f 9ff87d48 motufwa+0x365f1
9ff87d14 8e6eefd8 838d6478 00000000 85d74860 motufwa+0x3660c
9ff87d48 8e6d7600 8385c840 00000000 83665cc0 motufwa+0x32fd8
9ff87d74 81451275 85d74860 ef75976f 00000000 motufwa+0x1b600
9ff87db0 8131cdd1 8e6d7590 85d74860 00000000 nt!PspSystemThreadStartup+0x4a
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x19
Code: Select all
0: kd> lmvm motufwa
start end module name
8e6bc000 8e735000 motufwa T (no symbols)
Loaded symbol image file: motufwa.sys
Image path: \SystemRoot\system32\drivers\motufwa.sys
Image name: motufwa.sys
Timestamp: Thu Sep 06 18:13:47 2012 (5049201B)
CheckSum: 0007B8C8
ImageSize: 00079000
Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4
