Reverse Plug In and Reverse Phase not in DP 7.22?
- toodamnhip
I have always used the reverse and even reverse phase plug ins in the Audio plug ins window -Audio/audio plug ins/ reverse....etc...
The REVERSE and REVERSE PHASE Plugs are gone...lol...
Have they been left out of DP 7.22?
That would be really strange.
I installed so carefully that it seems very weird that it could be gone.
If it indicates an install issue, this make me a bit nervous as, after tons of bugs etc, I finally have my system working and I am not sure if I want to re-install.
Of course, getting hold of tech support at 2 pm LA time is impossible. I have my assistant dialing over and over..bzzzzz bzzzzzzzz
Any advise would be very much appreciated. It might even be cool if one of you amazing Nation members could e mail me the reverse plug for now.
I'll talk to tech support tomorrow I guess and, if it seems to risky to re-install, I'd love to just get the plug as a one off and drop it into the MAS plugs folder.
Also, if anyone is feeling kind, a list of plugs I should have would be great. I wonder what else I am missing? Having come from DP 5.13, there may be a few I am not aware of
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
- Dwetmaster
Re: Reverse Plug In and Reverse Phase not in DP 7.22?
pm sent
My guess would be that you installed Digital Performer with an update installer, not the full installer from the disc. Usually Digital Performer update installers do not install all the plug-ins. If there was no change from the previous version, then MOTU doesn't include them to make the installer program smaller. The Reverse and Invert Phase plug-ins almost never change, so they are often excluded in the update installers. The full installer from the DP installation disc always installs all plug-ins. Run the installer on your disc and then run the later update installers to get back to the current version.
- toodamnhip
What you said makes sense, but, it is my recollection that I installed from disks, and updated online only the latest of everything.1nput0utput wrote:My guess would be that you installed Digital Performer with an update installer, not the full installer from the disc. Usually Digital Performer update installers do not install all the plug-ins. If there was no change from the previous version, then MOTU doesn't include them to make the installer program smaller. The Reverse and Invert Phase plug-ins almost never change, so they are often excluded in the update installers. The full installer from the DP installation disc always installs all plug-ins. Run the installer on your disc and then run the later update installers to get back to the current version.
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
- daniel.sneed
Not in front of my DAW right now.
But, I remember loosing the Reverse plug in a previous DP transition.
I picked the plug from an older HD clone, and voila!
dAn Shakin' all over!
DP11.31, OS12.7.5, MacBookPro-i7-3.1Ghz-16GoRam-1ToSSD
- mhschmieder
Sometimes, AU plugs gets organized differently on first use (after initial validation) than on later launches.
I've noticed a few plugs bounce around in their naming and location in the drop-list, after updates or fresh installs.
In most cases, the vendor name gets dropped, pre-pended, or used as a sub-folder. So try all three possibilities to see if they're just "hiding".
Also make sure to run "repair permissions".
Go to Audio Menu>Audio Plug-Ins. You should see MOTU: Invert Phase (mono) and MOTU:Reverse (mono) listed.
http://www.davepolich.com
Invert Phase and Reverse are both still there. It sounds as if something just hiccuped during the installation.toodamnhip wrote: What you said makes sense, but, it is my recollection that I installed from disks, and updated online only the latest of everything.
- toodamnhip
I didn't know the installer had a pair of lungs.....Frodo wrote:Invert Phase and Reverse are both still there. It sounds as if something just hiccuped during the installation.toodamnhip wrote: What you said makes sense, but, it is my recollection that I installed from disks, and updated online only the latest of everything.
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Those ain't lungs, baby - it's just a very sexy DAW...toodamnhip wrote: I didn't know the installer had a pair of lungs.....
I love the sound of ROFL.
MLC, I can't recall which version it was, but do you remember when you had a similar issue during an installation in which your "MAS AudioUnit Support.bundle" wouldn't install after repeated attempts? Didn't MOTU send you an interim installer or something? It's been a while, so I forgot just how that got fixed.
I don't think the usual paper bag or hold your breath solutions for curing hiccups would apply. Did you sneak up on your computer and yell "boo"?
Seriously, these things don't happen often but they *can* happen. Sometimes we don't notice what's missing until well after the fact.
When DP went form 5.13 to 6, they changed the format of that file and if you tried to go back to DP 5 after installing 6, you had to delete the file manually. I was saved by a member of this board in a very troubling moment in production when he brought that to my attention as the problem. Another reason why I really never used DP 6.Frodo wrote: MLC, I can't recall which version it was, but do you remember when you had a similar issue during an installation in which your "MAS AudioUnit Support.bundle" wouldn't install after repeated attempts...
- toodamnhip
Personally, I take any "small" problem as a potential sign of a bigger problem. This makes no sense to me and it makes me wonder if the whole DP program should be re-installed. I am running pretty well now after I discovered the Antares bug.Frodo wrote:I love the sound of ROFL.
But there has been about a crash a day or so.
I will monitor this with an eye toward re-installing everything should other strange issues appear.
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
I've had about 4 or 5 crashes in the last week but with very heavy use and many hours of the program open and working. I don't mind the crashes as much as the -39 error that the file has gone south. that is totally unacceptable. Time Machine and multiple manual backups is the only possible protection but it's just wrong.
- toodamnhip
I've already had the auto backup in DP save my ass once.MIDI Life Crisis wrote:I've had about 4 or 5 crashes in the last week but with very heavy use and many hours of the program open and working. I don't mind the crashes as much as the -39 error that the file has gone south. that is totally unacceptable. Time Machine and multiple manual backups is the only possible protection but it's just wrong.
Yesterday, I almost blew a final master file and I was freaking.
I had burned the stereo mix and then I went to delete unused soundbites:
1) It took a very long time to select them all as if suddenly, there was a ton of unused soundbites, (it had not been too long since I had last done that so it shouldn't have been that way)
2) It couldn't delete because of one Fu %^$&^%&&%&ing file that was corrupt due to a peak pro file I had to make due to the reverse plug not working. (I reversed the file in Peak).
Suddenly, DP gave me an error message and I clicked OK and it would not stop giving me the damn message. I clicked like 50x.
Finally , i had to force quit. I was bummed thinking I lost my last 45 min of mix changes.
When I tried to launch the file agin, it gave an error message, maybe that error 39, I don;t recall.
But I was able to open the back up, which was 40 minutes too old, and then, once DP was opened, I opened the previous file that was messed up and this time ,,,it opened.
I quickly did a Save as and lucked out..
But this cra^&%&%&&%^p pisses me off.
It's like "Murphies Law"
DP, or some demon knows when I am about "done" and tries like hell to explode...
Adds a few new grey hairs to my most non-grey head...
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
