Fades always re-computing on a project (?)
I have a tune I'm working on with a lot of small crossfades (drum edits). Every time I open the project all of the little fades re-compute, taking a lot of time. I thought once a fade was created it was "remembered" by the project and didn't have to be computed every time.
Any thoughts why this is happening?
- jr213
Re: Fades always re-computing on a project (?)
I think it just does this for project files opened in 4.6 that were created with a previous version. 4.6 uses a different (and slightly buggy) method of calculating fades that is supposed to be faster, though I don't see it.
DP6.02, OSX.5.latest on Quad 2.66GHz MacPro w/ 3GB RAM, MOTU 828mkII, UAD-2 Duo, Altiverb, PSP, TriTone, Omnisphere, Komplete 5
Thanks jr...Well, this was a project that originated in 4.6...hmmmm....
Hey, we're kinda neighbors. I'm live down near San Antone....
- Adam YW
EXACT SAME PROBLEM
we are new DP users and are having the EXACT same issue with fades re-computing that you posted about here. We have done drum editing which has a gazillion fades and it takes like 10 minutes for the session to re-calcuate them every time.
Did you ever figure this out? HELP!!!! Can anyone help??
Adam
Adam
Adam
Yellow Wood // Windsor ON CA // www.yellowwoodmusic.com
Possible fix...
I've been having the same problem.... It's embarrassing when a client is sitting with me and their track is glitching because of background processing.
Anyway, I think the problem is that it's doing a BUNCH of background processing: fades, file analysis, finding beats, etc., and it doesn't show you in the processing window either.... So, you have to go to Preferences/Settings, General: Background Processing and turn off the things you don't need, which for me is most of them....
That seems to fix it for me for now...
paul
paul
Paul Tavenner
Big City Recording Studios
Man Alive Music Productions
Los Angeles, CA
Los Angeles, CA
I've been getting this problem intermittently.
It's not because the files were created in an earlier version - I've been working on the same files in 4.61 for a while now.
It even happened twice on the same file today, during two different work sessions. Hadn't turned off the computer, or even worked on another DP file, in between these sessions.
It's really annoying. I have to wait a few minutes for the fades to be calculated before I can start working.
Anybody?
Anybody?
Bob
M1 Max Mac Studio - 64 GB RAM - macOS 15.4
MacBook Pro (15-inch, Mid 2012) - 2.6 GHz Intel Core i7 - 16 GB RAM - macOS 14.4 via Open Core Legacy Patcher
DP 11.23
Metric Halo ULN-8 mk4
DP 11.23
Merging shouldn't be necessary, and it begs the question of why the crossfades have to be recomputed when they'be already been computed and stored in the 'fades' folder.
Bob
DP 11.23
DP 11.23
I've got a 4.61 project that just started doing this and came here to post and found out i'm in the same boat as y'all.
Hmmm.
Very weird.
Hmmm.
Very weird.
Fibes
"You can like it, or not like it."
DP 7.24, 12 Core 2.66, Reason, Live, UAD-2 full meal deal, Sonalksis 315 & 517, DUY Everpack, Altiverb 6, Apptrigga, Autotune 5, OHM Force Experience, Audio Damage Dishord/Adverb/Dubstation, PSP full meal deal, Camelphat/Space, Wave Arts Power pack and many more.
Update:
I emailed magic d about this yesterday, but haven't heard back.
I called MOTU tech support this morning (at least it was morning here on the west coast) and to my surprise got through the first try.
After checking with somebody else there, the tech (forgot his name) came back and said it shouldn't be doing this.
At his suggestion, I created a new file, then did 'File->Load' and loaded in all the data from the problematic file. After background processing was done in this new file, I saved and closed it. When I reopened, it started all over again with the processing, so no dice.
Next he suggested, for some reason, that I try a 'Save as'; I did this (without duplicating audio data) and it still didn't help. When I reopened the file, processing started again.
That's all he could come up with. He said it's not a 'known issue' with DP 4.61. (OK, but maybe it WILL be...)
I also tried opening a backup version of this file from another hard drive, but got the same results.
In this particular file, it took 6 min, 10 sec to do the processing (with no other work going on). With this many fades, I may have to do merges before I'm really done editing as a work-around, just so I don't have to wait so long.
Bob
DP 11.23
DP 11.23
They need to get on this ASAP.
Fibes
