BWAV support SIT IN! (no conversion to SDII anymore,please!)
- vier-personen
I‘m now spending the whole day importing .BWAV files DP to mix and I am fed up, so I‘m starting this
If you hate the way DP converts bwavs to sdII, join me!
---edited for clarity---
DP 5.12/OS X 10.4.9/MacBook C2D 2.0 1GB Ram/RME Fireface 400
- robstudio
not sure here either, DP imports the waves properly, and fast ... all day ?? Now the reason I had to import wav files however .... stinkin omf ...lol
David, do I recall correct, you posted that you have a 328 digital console... if so, please take a peek here if you have a moment...
http://www.motunation.com/forum/viewtopic.php?t=23459
Regards, Rob
Regards, Rob
Mac Pro 2x2.66GHz, 3 GB Ram, OS10.4.11 (not using 10.5), DP5.13, 2408mKIII, 2408mKII, 328 Digital Console (x2), FostexD2424, Micro Lite, QSR, SPX90, URS, PSP, Altiverb, Alphatrack, Shuttle
I think what you're after is DP to playback WAV files without having to import to SD2. I don't know much about the issue, but it seems like from what I've read, Broadcast WAV is what they should consider doing due to the timestamping and the fact that this format is becoming pretty ubiquitous.
- vier-personen
David Polich wrote:Not sure what you're complaining about. I can import .WAV files into DP just fine. Please explain further what your situation is.
of course you can import bwav files, but DP converts them to sdII - which takes all day on my macbook for this project which has 30GB of bwavs to import - there‘s also the thing with stereo files - if I drop them on the area in dp which opens a new track for the file, DP makes 2 new stereo tracks (one called overheads22 and one overdeads222 or so) so I have to edit out the double files...
also at one point my project got corrupted and I had to start over.
- vier-personen
you are right, that‘s what I meant, see above.James Steele wrote:I think what you're after is DP to playback WAV files without having to import to SD2. I don't know much about the issue, but it seems like from what I've read, Broadcast WAV is what they should consider doing due to the timestamping and the fact that this format is becoming pretty ubiquitous.
bwav is what I encounter at practically every recording situation I was attending in the last years - except if I pull out my DP...
What they said...vier-personen wrote:you are right, that‘s what I meant, see above.James Steele wrote:I think what you're after is DP to playback WAV files without having to import to SD2. I don't know much about the issue, but it seems like from what I've read, Broadcast WAV is what they should consider doing due to the timestamping and the fact that this format is becoming pretty ubiquitous.
Broadcast Wav is the way to go I agree. As Mr. Steele said: timestamping and the fact that it's become the industry standard.
2012 Mac Pro 12 Core, OS 10.8.5, 64 gigs ram; 2408 (3), 308, DP 8.07 http://www.daveconnor.net
- Timeline
Agree but this won't help.
MOTU does not listen to these types of complaints and knows well already that we want it.
- gearboy
I'll talk to them at AES. I'm sure that'll help.
OS 10.4.11 - G5 Dual 1.8GHz, 3GB RAM / Mac PB G4 1.5GHz, 1.5GB RAM / Apogee Duet / MOTU 828mkii w/BLA Analog & Clock mod / MOTU DP4.61 / Live5.2 / Peak 4 & 5 LE / Izotope Oz3, Sp, Tr / Waves Ren Max / TRacks, Miroslav / NI Komplete 5 / GF impOSCar, MiniMonsta, M-Tron / Automat / Nomad Factory Vintage Studio Bundle / apTrigga / Audio Hijack Pro
My recording blog: http://www.ipressrecord.com
- vier-personen
- vbassguy
Motu was a no show at AES last year.....I wonder if they'll show this year?gearboy wrote:I'll talk to them at AES. I'm sure that'll help.
G5 quad 2.5 ghz w/ 8 gigs ram, OS 10.5.4, DP 5.13,DP6, Mach 5,Mach 5 v2, SI, two loaded UAD-1e cards, PCIe 424, two Black Lion Modded 24 I/O's, Harrison 3624 console, cool old mics, pre's and compressors.....Great sounding Rooms.........
www.RRRPROD.com
www.RRRPROD.com
