Tips for setting up a new M2 max Mac Studio?
- davedempsey
I have just acquired an M2 Max Studio - standard model 32gb and 512 storage - for a great price, unopened box/unwanted gift. I’m about to set it up with DP and DSP Quattro, Waves, Izotope, Plugin Alliance, Softube, Zynaptiq and NI plugs - no VIs. I’ll only be doing mixing, stem and/or stereo mastering as I can no longer play keys or guitar due to a recent diagnosis of ALS.
Any tips and suggestions that will help me get everything running smoothly with minimum fuss will be greatly appreciated as I have low energy levels and limited stamina nowadays.
Dave
Dave
Lots of stuff and a recently acquired ability to stop buying
Re: Tips for setting up a new M2 max Mac Studio?
Congratulations on the new Mac. My only input would be that I would do a fresh install of the apps. I would not use migration assistant. You’ve got a brand new computer so keep it pristine. Again, you will enjoy it.
What James said. Make sure to download all the Apple Silicon Native plugins. Enjoy!
HC Markus
M1 Mac Studio Ultra • 64GB RAM • 828es • macOS 14.5 • DP 11.31
- davedempsey
Should I avoid the plugins that aren't or will Rosetta 2 look after that? There's some Plugin Alliance that aren't native and a few Izotope.
Based on my experience, I believe almost all non-Apple Silicon Native plugins will work well under Rosetta2 with DP11 running Native. I only had a couple (BFD3 and three from Boz) that did not work unless DP was run in Rosetta Mode. BFD3 is now Native; Boz is still lagging.
The only plugin I now run under Rosetta is Altverb 7. It works well, but DP must be run in Rosetta Mode to authorize it. You can choose to run DP under Rosetta in the DP App "Get Info" screen. Check the "Rosetta" box, boot DP, authorize Altiverb, close DP de-select "Run in Rosetta", re-boot your Mac, and Altiverb should appear when you run DP again.
There is a $3.00 App (Apple App Store) called PlugInfo that will display info about and let you locate all audio plugins on your Mac. Recommended. It is also available for free here (but why not support the developer for $3.00?) https://www.thinkersnacks.com/as-pluginfo.html
HC Markus
- hammerman
I just did this.
What James and Markus said.
Fresh install everything. It took me two days but it was worth it. Also, for external storage, there are some great options. If you need speed (for Photos Library or video editing) there's Envoy Express Pro FX (2800/MB/s). Also OWC Envoy Express (1550MB/s) which uses NVMe.2 blades - external Thunderbolt enclosure. https://eshop.macsales.com/shop/Thunderbolt Plenty of cheaper options too there and elsewhere.
I use a slow spinner 8TB for Time Machine backups and a 4TB slow spinner for Carbon Copy Cloner as a second backup option. I have a 4TB internal.
Have fun!
Have fun!
M2 Mac Studio Ultra - 64 GB RAM - Sonoma - DP 11
- davedempsey
Thank you gentlemen. I’m up and running and very happy with workflow and abundance of cpu grunt. The only problem I had was caused by Acoustica ViennaSystemwide which was interrupting core audio device selection and clocking, causing Motu Audio System crashes. I was using the au plugin of Vienna to compensate my Planar headphones but Systemwide was self-selecting as an additional audio device and the clock source. Uninstalling Systemwide settled that disagreement .
I’ve been working on a live recording of Hat Fitz and Cara, which I made when I provided audio production for a Blues on the Water harbour cruise here on Sydney harbour back in 2017. The beautiful old wooden boat presented problems - the low frequency hum of the diesel engine in every mic channel and the constant changing level of audience noise being the most problematic. I’ve been using some AI assisted plugs to minimise these characteristics without damaging the performance. These plugs are very cpu hungry but this mac studio is not even starting to work hard. Cheers, Dave.
