M4 input noise?
M4 input noise?
Hi! I know that the two mic inputs provide quite a lot of gain, but I'd like to know if it's normal...in the image you can see that if I set the gain past 4 o'clock (and it is not crancked all the way up) there's a lot of noise coming from the input meters (and I can hear that in my DAW). This is happening as you can see with no mic connected but it's just the same with a xlr cable and mic inserted. Is it all good?? Does your M4 do the same?
My system is laptop HP zbook i7 with Windows 10.
- motuNoise.jpg (333.15 KiB) Viewed 1398 times
Re: M4 input noise?
If I'm reading the switches and knobs correctly, you are seeing the input from your PC.
If that's not it, we need more information.
Re: M4 input noise?
Try unchecking/disabling 'Use lowest latency safety' in the M4 control panel.
DP 11.31 PT 2024.3 VEP 7.x with various VIs
Re: M4 input noise?
it's already unchecked.
Re: M4 input noise?
nope, it's just the front inputs 1 & 2 level metering (apparently they work even with no cable/mic/instrument inserted).mikehalloran wrote: ↑Sun May 08, 2022 3:45 pm If I'm reading the switches and knobs correctly, you are seeing the input from your PC.
Re: M4 input noise?
Does it anything change when you rotate the In/Out balance counterclockwise?
Re: M4 input noise?
doesn't change. and also doesn't change whether the MON button is on or off.mikehalloran wrote: ↑Mon May 09, 2022 9:36 am Does it anything change when you rotate the In/Out balance counterclockwise?
Re: M4 input noise?
I just contacted the Motu support via chat and they say it's just the regular noise floor of the unit....so it's normal
but I just wanted to compare with someone else's M4 here...
Re: M4 input noise?
I get one bar on the meter with the gain full tilt and quite a bit of noise in DP with a track record enabled for input one or two ~-48db. I also start to get noticeable noise just after a one o'clock setting, but nothing on the meters. That's with the output volume full on. In my previous post I misunderstood what was the issue.
Re: M4 input noise?
thanksCharlzS wrote: ↑Mon May 09, 2022 12:03 pm I get one bar on the meter with the gain full tilt and quite a bit of noise in DP with a track record enabled for input one or two ~-48db. I also start to get noticeable noise just after a one o'clock setting, but nothing on the meters. That's with the output volume full on. In my previous post I misunderstood what was the issue.
- Primary DAW OS: Windows
Re: M4 input noise?
If you plug 2 48V mics and turn them on, does the noise is still there ??
