Track Folder Problems
I'm wondering if anyone else has had this problem. Whenever I delete a track folder, empty of or full, DP locks up and spins. I am forced to restart the program. Does anyone have advice to solve this problem? Thanks!
Re: Track Folder Problems
I have the same problems and no solution until now.
It is also not possible to move folder to another position.
And since today it isn't possible, to open any Soundbyte Window:-((
OS 10.14.6, iMac i7.3,5 with 32 GB Ram, 828x, Miditimepiece AV, DP 10.00 (ger.)
MachFive 3, MSi, Ethno 1, Omnisphere 2, Sampletank 4, Forest Kingdom II, Desert Winds, EWQLSO-Silver, Real Guitar 2, VLP120, PLP120, VCP120, Liquid Saxophones, Elastic, The Resource, Wave Arts PowerSuite 4+5 and Master Restoration, Kontaktplayer, Absynth 5, Ni Action Strings etc.
I'm having this same issue.. Can delete tracks, but not the folder. Tried loading chunk in a fresh session, new prefs, no luck.
I'm not having this problem with DP10.11.
828x MacOS 14.7.1 M1 Studio Max 1TB 64G DP11.32
- sonus
Me too, never had any problems either moving or deleting track folders.
MacPro 5.1 2x3.46 twelve core, 64Gig, OSX 10.15, Mac Studio Max 32Gig, DP11.13, RME HDSPe FX, Softube Console 1 & Fader, UAD-2 quad, Soundtoys v5, UVI Falcon 3.0, GForce Mellotron & String Machine , Waves Rennaissance...
Weird.. Maybe something in my template.. Am in the process of updating my template and now I can't even DRAG an existing folder to a different location without it beachballing. Tracks are fine, not folders.
I have seen this several times and EVERY TIME is was user error. Not carefully selecting the proper choice in the dropdown.
I'm not saying that you guys are having the same issue, but again, I have seen it quite a few times and it is ALWAYS user error.
Just sayin'
Just sayin'
- waterstrum
I'm usually adding track folders and seldom delete them.
I use several in my projects and just for test purposes, tried a couple of track folder deletes.
In each case, the folder went away with no ill effects.
In each case, the folder came back with undo.
No crash, no problem.
This is on DP10.11/OS10.14.6
Wishing you a solution for your system.
Keep us posted.
Keep us posted.
All is well
- FMiguelez
Most times folders work fine for me, but they do get stupid and start behaving unreliably at times, seemingly randomly.
This thread details lots of folder issues with pics and gifs and everything>
viewtopic.php?f=1&t=62017&start=15#p527966
Not seeing the problem on my system.
DP 11.32, 2020 M1 Mac Mini [9,1] (16 Gig RAM), Mac Pro 3GHz 8 core [6,1] (16 Gig RAM), OS 14.6.1/11.6.2, Lynx Aurora (n) 8tb, MOTU 8pre-es, MOTU M6, MOTU 828, Apogee Rosetta 800, UAD-2 Satellite, a truckload of outboard gear and plug-ins, and a partridge in a pear tree.
