Selecting soundbites
dixiechicken
Post by dixiechicken »
Hi folks - DC here!
I cant selet my sounbites in the the sequence editor window?
This is on my PC laptop running windows 10 and dp 9.52.
On my Mac Pro I just click on the soundbite and it gets highlighted.
(in this particular case I wanted to slow down the soundbite to the sequence tempo)
I feel stupid - it must be a simple thing really :(
Cheers: Dixiechicken!
My God it's full of stars....
Mac Pro 6-Core Intel Nehalem/Xeon 2.93 GHz 32-GB ram, OS-X 10.13.5-Swe, DP-9.52, Unisyn-2.11, 828-MkII,MTP-AV usb, Latest drvs, Wavearts plugs, Kurzweil-2000, Proteus-2000, EPS-16, Pod-II,
Digitech RP-155, Soundcraft UI-16, Emes Kobalt monitors.
dixiechicken
Re: Selecting soundbites
DC here!
With help from MOTU - problem solved.
Removing the contents of the Preferences folder did the trick.
1) Shut down DP
2) Go to:
C:\Users\username\AppData\Local\MOTU\Digital Performer\Preferences
3) Throw the contents into the thrash.
4) Re-start DP
5} Manually configure the driver for the soundcard -
change the windows theme to oamething you can stand
CAVEAT:
Opening a big project DP-file may contain other configurations
that must be done manually - I simply don't know.
BTW:
Changing the soundbite format between various such
Aif, wav, mp3 etc etc - did nor solve the issue
Reparing DP from the controlpanel--> Program & Functions
did not help the issue either.
