DSP Quattro 5 is out
Pretty big update...finally 64 bit, lots of new
features and new GUI. $40 to upgrade from
a previous version.
Still the only worthy successor to the discontinued
BIAS Peak, which was truly the best Mac-based
audio mastering application ever. Forget about
the bloated, confusing Wavelab or feature-poor
Triumph or overpriced Sonic Studio.
The authorization process is still confusing but
Stefano will respond immediately if you email
him about any issues.
http://www.dsp-quattro.com
a previous version.
http://www.davepolich.com
Re: DSP Quattro 5 is out
Go to pages 4 & 5 for a lively discussion of this and the hoops some of us have had to jump through during the upgrade process.
viewtopic.php?f=3&t=62108
Yeah, the DSPQ 5 authorization process is
confusing. I emailed Stefano about it and he
answered straight away. My buddy Greg
(Waxman) had the same issues, emailed
Stefano and he answered Greg immediately
as well.
as well.
Spent more time with DSPQ5 yesterday.
Stefano knocked it out of the park. It sounds
better, the plugin effects implementation (u
could run over 150 plugins in a session) the
CD layout and authoring, ability to save and
load any audio format including 32 bit Float,
the new pitch shifting and time stretching,
all amazing. What really knocks me out is
how much better it sounds. Stefano rewrote
the entire app from the ground up, and it is
now easy to understand why it took him so long.
Highly recommended.
Highly recommended.
Great to hear that. I thought DSP 4 sounded good. I always opened up mix bounces in it to listen before deciding whether it was finished because it always seemed cleaner to me in DSP-Q than in anything else.David Polich wrote: What really knocks me out is how much better it sounds.
- Bennie Sims
Great Job!! A much better program now!! Worth the wait!!
Mac Pro Six Core Trashcan OX.10.13.3,Macbook Pro 2.53 GHz Intel Core i5 OSX 10.11,DP 8.07 and 9.52,Protools 2018.4 and 10.3.9,Logic 10.4.1.,Reason 8,Waves V9.7. Diamond Bundle, Mach Five 3.2.1, Vir 2, Kontakt 5.3, Melodyne Studio 3.2.2.2, Melodyne Single Track, Motu 2804 MK3, Apollo 8 Quad,Apollo 8 Duo,UAD 2 FireWire Quad Satellite, UAD Thunderbolt Quad Satellite, Rosetta 800, Avalon Vt 747sp, Focusrite 4x Red One, UAD 4-710d, Raven MTi 2 3.3.1, Motu MIDI Express XT.
Just upgraded from version 4. Cool so far! Yes, the authorization process was a little bit involved, but all worked out. Here's a niggling little oddity. Why does the "Save..." option in the File menu have the ellipses (...) after it when it doesn't open any dialog but is the basic "Save" command?
Funny, I thought I was the only one having trouble with the authorization. Long and complicated for me. Its done now, was ready to give !
2009 8 Core 5.1, 2012 6 Core MacPro,s , (32 gigs Ram) Mojave 14.6, Radeon 570, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT ,DP11 , PT 2022.12, Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 10, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
Not sure why, James. You can email Stefano to ask.James Steele wrote:Just upgraded from version 4. Cool so far! Yes, the authorization process was a little bit involved, but all worked out. Here's a niggling little oddity. Why does the "Save..." option in the File menu have the ellipses (...) after it when it doesn't open any dialog but is the basic "Save" command?
BTW, there is already an update - version 5.0.3. Available in your UserArea at the DSP Quattro
website.
This looks pretty good for $80. I might go for this later next week.
MacBook Pro (16-inch, 2019) 2.3 GHz 8-Core Intel Core i9 16 GB RAM OSX 11.2 Big Sur
UAD Apollo Quad DP11.22 some Waves, Soundtoys, Digital Performer 11.2, Reason 12, iZotope 11, and lots of real instruments to play
Haha. I’m pretty sure it’s just a mistake as it breaks with convention AFAIK. Ellipsis after a menu item pretty much always means there’s a subsequent dialogue box that will open. Still, it’s the kind of mistake that makes the person pointing it out look like a petty nitpicker. (Or OCD!) So I don’t want to email Stefano over something so trivial.David Polich wrote:Not sure why, James. You can email Stefano to ask.James Steele wrote:Just upgraded from version 4. Cool so far! Yes, the authorization process was a little bit involved, but all worked out. Here's a niggling little oddity. Why does the "Save..." option in the File menu have the ellipses (...) after it when it doesn't open any dialog but is the basic "Save" command?
- mhschmieder
James is right about HUI guidelines regarding the ellipsis. It indicates that the command is not complete in and of itself, which usually infers a dialog will appear for setting or confirming parameters.
- philbrown
Does anyone happen to know how to open existing playlists from V4? I couldn't figure out a way to open or import them and I have hundreds of them I need access to. Luckily V4 still runs and I can get my work done. The new version is certainly more visually appealing but for a guy who uses V4 every day it feels like something from a completely different company. I hope I can open my old playlists somehow.
I don't think that is possible, at least from my understanding of the FAQ:philbrown wrote:Does anyone happen to know how to open existing playlists from V4? I couldn't figure out a way to open or import them and I have hundreds of them I need access to. Luckily V4 still runs and I can get my work done. The new version is certainly more visually appealing but for a guy who uses V4 every day it feels like something from a completely different company. I hope I can open my old playlists somehow.
https://www.dsp-quattro.com/dspquattro/ ... .html#faqs
828x MacOS 13.6.7 M1 Studio Max 1TB 64G DP11.32
- philbrown
Thanks for the link, cuttime. I should have read up more before I purchased. Hard to believe there wasn't some way to import old playlists. Looking forward to the full manual to answer other questions.cuttime wrote:I don't think that is possible, at least from my understanding of the FAQ:philbrown wrote:I hope I can open my old playlists somehow.
