I'm a jazz pianist/educator getting into recording using the PMI Bosendorfer 290 and have a few general questions about how to obtain a better sound.
I probably don't even know enough to ask the right questions, but I do know that my sound is very thin or tinny when I record a solo track in DP 4.6. When I listen to the demo tracks on the East-West web site, they sound very full and have a much softer sound which is what I want.
I've been recording a stereo track using the first generation MOTU 828. I have played around with reverb settings, EQ, Channel Strip (presets), etc. and can't seem to fatten the sound--it still sounds thin and tinny. A friend suggested going through a preamp and back into the 828. I'm not even quite sure how to do that using my Mackie 1202.
Any suggestions would really be appreciated.
Thanks,
Aaron
Software Piano
Are the demos made with the stock sounds that come with it? Sometime the demos are made with another library and it can get a little confusing...
If all else fails... just run it through a nice tube pre-amp and re-track the returns. Since this is a VI your really @ the mercy of the quality of the actual samples. You know... Altiverb is a great environmental process for anything that needs a warm sound to it. One thing.. I take demos with a grain of salt man, you never know what people use to make demos so beware of that "instant gratification" thing.
I tried to find out what presets where used and nobody at East West knew the answer.
I'll try your suggestions except the one using Altiverb since I don't have it at this point. I did play around with the eq and was able to get a warmer sound. But sitll not as full and fat like the demos.
By the way, since I posted this question I got Ivory and like it much better than the PMI Bosenforfer.
Thanks,
Aaron
Thanks,
Aaron
