'Error 5570' while trying 4,1 to 5,1 firmware update
I'm trying to do the firmware update from 4,1 to 5,1 for my 2009 MacPro 2x2.26 Quadcore.
(the current firmware is the MP41.0081.B07)
I've downloaded the firmware upgrade program from here: http://forum.netkas.org/index.php/topic,852.0.html
While running the program, I get the 'Error 5770' message.
Some suggestions to the problem from on-line searches say:
- problem could be caused by my having El Capitan.
- problem by having 'SIP' enabled ....(*I did try it by rebooting with SIP disabled, but still got the same error message)
- problem might be that I have an SSD as my boot drive.
Any other suggestions or ideas?
I know that many of you have done this, and I'm late to the party.
DP 11, OS Ventura
http://www.cammillarmusic.com
- buzzsmith
Re: 'Error 5770' while trying 4,1 to 5,1 firmware update
Following.
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
I'd suggest review of the Netkas thread, especially towards the end.
Here's the latest successful upgrader's take on steps required:
I had best results updating from a Mountain Lion start up. When I first did the update in 2012, the original installer worked. The above-noted Pigsyn's patch may now be necessary; I used it when I did my last update (my backup Mac Pro) this past summer. Another one I assisted with about 1.5 years back required a patched updater as well.
Good Luck!
This is also found in the thread:1. Boot into recovery mode and disable SIP since I'm running El Capitan
2. Reboot [Turn off any outbound firewall like LittleSnitch since the script needs Internet access]
3. Mount the MacProEFIUpdate dmg (for 5.1)
4. Run MacEFIRom's utility.
5. Shutdown and power back up by holding the power button until light flashes and tone sounds [and screen appears with fat progress bar]
6. Verify Boot ROM Version: MP51.007F.B03
7. Boot into recovery mode and enable SIP
8. Reboot
As I found out DO NOT RELEASE POWER BUTTON after tone until screen appears with fat progress bar.
Pigsyn's patch and instructions can be found in Page 64 of Thread, posts #964 and 966.In general it seems that the most common reasons why the '5,1' firmware upgrade may fail are:
Error 5570, due to Apple's renaming of their '5,1' firmware disk-image download, which can be resolved either by using pigsyn's patched edition of the tool (which incorporates the new DL link), or manually DL'ing & pre-mounting that disk image
not having the latest '4,1' firmware ('MP41.0081.B07/B08') already installed
using a non-(Mac-)EFI graphics card
using a 'non-traditional' boot drive (e.g., non-GPT/-EFI, or PCIe/SSD, etc.), and/or running under a recent OS that has SIP enabled (e.g., OS X 10.11 'El Capitan' in default config)
{Apple has also suggested in the past, for regular firmware updates, that it may occasionally be necessary to remove all non-essential external devices, leaving just a mouse, keyboard and monitor attached. I personally did not have to go that drastic bare-bones route, but I guess it couldn't hurt if all else fails.}
Good Luck!
M1 Mac Studio Ultra • 64GB RAM • 828es • macOS 14.5 • DP 11.31
Re: 'Error 5570' while trying 4,1 to 5,1 firmware update
Ho! Ho! Ho!....it worked!... what a gift!....thank you H.C. Markus!
I followed your lead to the pages and posts in the Netkas thread.
- I rebooted, and disabled SIP in El Capitan; then restarted
- I turned off the Firewall in System Pref/Privacy
- I downloaded the 'patch.tgz' that was attached to the bottom of the post #964
- (I didn't need to download the 'fixed Firmware Patched.zip from bottom of post #966, as I had downloaded the original Firmware Upgrade patch yesterday from the very first post in the thread ... hmm,...maybe i could have just used this new attached fix? Anyhow....)
- then, I made sure that both downloads were in my Users/Downloads
- then, I opened Terminal and carefully typed in the commands as listed from post #966, (making sure to have the spaces in the right places)
- followed instructions, and magic!
I'll be on the search for the processor upgrades in the New Year and put in some more RAM as well.
Great way to end the year! Thanks... I've been following your wisdom on this upgrade path for a couple of years already!
DP 11, OS Ventura
This is great news artfarm, and encouraging to others who are considering the 4,1 to 5,1 upgrade.
Thanks for sharing your success, and happy holidays!
Thanks!.... have a California Christmas in the sun!
Up by Toronto here 'tis a little colder... makes you appreciate the egg nog.
DP 11, OS Ventura
- buzzsmith
Okay, maybe I'm just slow or just not on top of my game today!
I'm not sure of the correct order to do all of this.
Do I do the Terminal commands first?
When I did, I got this...(Copied each line individually and hit return after each one.)
Last login: Mon Jan 2 12:18:46 on console
carroll-j-smith-jrs-mac-pro:~ BuzzySmith$ cd $HOME/Downloads
carroll-j-smith-jrs-mac-pro:Downloads BuzzySmith$ tar -zxvf patch.tgz
x 2009_2010.patch
carroll-j-smith-jrs-mac-pro:Downloads BuzzySmith$ patch Mac\ Pro\ 2009-2010\ Firmware\ Tool.app/Contents/Resources/Scripts/Mac\ Pro\ 2009-2010\ Firmware\ Tool.scpt 2009_2010.patch
patching file 'Mac Pro 2009-2010 Firmware Tool.app/Contents/Resources/Scripts/Mac Pro 2009-2010 Firmware Tool.scpt'
Reversed (or previously applied) patch detected! Assume -R? [n] n
Apply anyway? [n] n
Skipping patch.
2 out of 2 hunks ignored -- saving rejects to file 'Mac Pro 2009-2010 Firmware Tool.app/Contents/Resources/Scripts/Mac Pro 2009-2010 Firmware Tool.scpt.rej'
(I highlighted in red the question that threw me. I didn't know so I entered "n".)
When I tried to run the MacProEFIUpdate I got...
Alert
This software is not supported on your system.
So, for an apparent dummy , would one of you kind gents lay out the instructions and order of implementation for me line by line?
(BTW, I did check my current firmware. It's reported as: Boot ROM Version: MP41.0081.B07)
Thank you!
Buzzy
x 2009_2010.patch
Apply anyway? [n] n
Skipping patch.
Alert
Thank you!
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- buzzsmith
I found a YouTube video. It looks so easy!...I hope.
https://www.youtube.com/watch?v=YU8p86qHnek
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Good Luck Buzzy. If you encounter issues, review artfarm's info and the referenced posts at Netkas. And please let us know once your MP is reporting it is a 5,1!buzzsmith wrote:I found a YouTube video. It looks so easy!...I hope.
- buzzsmith
Thanks.HCMarkus wrote:Good Luck Buzzy. If you encounter issues, review artfarm's info and the referenced posts at Netkas. And please let us know once your MP is reporting it is a 5,1!buzzsmith wrote:I found a YouTube video. It looks so easy!...I hope.
In the video he didn't have to use any Terminal commands. Not sure why not after looking at the Netkas dialogue.
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- buzzsmith
So far, so good!
I had to "finagle" the MIDI setup a little, but a second restart showed the 5 or so hardware modules.
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
YES!
Great job Buzz.
I missed the terminal stuff you mentioned earlier. I never had to go into terminal to do the EFI update. I think it is only necessary under Sierra, as SIPP must be disabled to update the EFI.
Anyway, all that is now behind you, and the doors have opened to a much faster CPU if you feel the added performance will assist you. Plus, Sierra is now available to your Mac. Congrats!
Great job Buzz.
- buzzsmith
Thanks, HC!HCMarkus wrote:YES!
Great job Buzz.
Faster CPU (and probably more RAM) is in the plans.
Step by step.
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Makes you sweat a bit, doesn't it?
Glad it worked for you too!
DP 11, OS Ventura
- buzzsmith
For sure!artfarm1 wrote:Makes you sweat a bit, doesn't it?
I was waiting for that successful reboot!
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
