No. I've talked to MOTU, and they said that Apple simply hasn't provided the hooks in OS X for that. No reason why they couldn't, just that they haven't, and like so many Apple features, once they get it to a reasonably working status, they often cease development on it. I've hoped for that for years.Basstrup wrote:Agreed OS X's Spaces is amazingly awesome. Question: Have you found a way for DP to remember which spaces to "send" windows to when opening a project? Or do you assign windows to spaces manually?Shooshie wrote:If you work in OS X's Spaces, as I do, it's so fast to switch to any window, because the ones you use are always open. No problem to add a track in the place desired. Switch to the Tracks window, add the track, switch back. Too fast to be a problem.
Best regards
Bo
However, there IS a very easy way to distribute the windows, which I demonstrated in the video below:
Using Mission Control in DP:
- Tips Sheet Thread You Tube Video:
Also, in response to Jack's wish to have an Add Track in the Mixing Board, I 2nd the motion. But I'd also like to have a way to select a track in the board, so that adding a track would put it where I want it. There are other good reasons to be able to select a track from the Mixing Board, though I can't remember what they are off the top of my head. I always swear that I'm going to write them down as I come across them, but then I'm always too busy to do that, so I don't, then I forget... So... MOTU... trust me; there's at least a good reason, maybe more, to be able to select a track from the Mixing Board. Maybe just a little check box at the top or something which responds to dragging over it, but out of the way of the typical drag so as to minimize accidental selection.
Then, using the menus or keyboard commands, we should be able to add a track easily. I don't know if it's necessary to actually put the "Add Track" in the Mixing Board menu, but why not? I mean, we do have the main menus, and we have keyboard commands, but redundancy isn't a bad thing if it's not in anyone's way. In the Mixing Board menu, it ought to be just fine. But let us select tracks from the Mixing Board. It could be used as another way to group tracks, too. But that's for another suggestion.
