Opening an OMF in DP, a work around
Hey guys, this works for me. I opened an OMF file in Audio Desk 4 and saved as a DP file.Then I opened that in DP8. It worked for me. Can anyone try that please. May be a work around the problem with DP and OMF files , thanks let me know how anyone fares with this !
2009 8 Core 5.1, 2012 6 Core MacPro,s , (32 gigs Ram) Mojave 14.6, Radeon 570, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT ,DP11 , PT 2022.12, Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 10, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
- ghobish
Re: Opening an OMF in DP, a work around
What problems are you seeing, specifically? I open FCP7 OMFs in DP8 all the time.
Gary Hobish
San Francisco, Ca
http://ahammer.com/mastering
San Francisco, Ca
Never worked for me since DP6. It will open the file then crash the program. It does create a folder though. Still will crash if I try and open the saved file in the project folder. I open the OMF files in PT8-11 with no problems using DigiTranslater so I know the files are ok.
- ghobish
DP6 was flawed that way for me too, but haven't had an issue since 7.
Gary Hobish
San Francisco, Ca
San Francisco, Ca
What happens is when I get a new version of DP it works a few times then crashes from then on. When I have a chance I am going to trash prefs and stuff. I am determined to figure this out.
- ghobish
Does it happen if log in with a clean, vanilla user profile? Or if you disable plug-ins?
Gary Hobish
San Francisco, Ca
San Francisco, Ca
Not sure yet. Need to take some time with this.There are no plugins in the opening file. Where would I disable the plugins Ghobish ?
