Suddenly, MIDI F# 3 wont play in DP 7.24/ RESOLVED!
This is weird and cropped up recently out of nowhere.
I cannot play F# 3 in Dp. Long story short, it's definitely not my controller keyboard. The problem is in DP. Its as if one note is being filtered out.
Everything works fine in Logic Pro as a test. Standalone VI's work just fine. But the minute I startup DP, I am unable to play that one note.
As another test, I set it so the recording/playing starts when a key is pressed. Well, indeed, that F# 3 when pressed starts the sequence. In fact, when I record in a MIDI track, everything records fine including aftertouch on that note. But the actual note wont play or record. Just that note. So odd.
Im a 30 year DP/pro composer and I'm just baffled at this new development. Knowing me, I have probably done something wrong accidentally, but cannot for the life of me figure out what it was.
Has anyone seen this? Help?
Thank you in advance.
Best, Kevin
Best, Kevin
Re: Suddenly, MIDI F# 3 wont play in DP 7.24
Yes I remember this happening. The note is assigned to a command.
Check your commands in DP, mine was usually assigned to a chunk if I remember correctly. Strange..
- Len
DAW Mac Pro 6-core 2013 | 64Gb RAM | 10.11.6 | Metric Halo ULN-8
DP 9.5 | VE Pro 6 | Kontakt 5
Len! That was it! I can't thank you enough. It was indeed in commands under chunk.
I wasted hours on this and fixed it in 30 seconds.
I owe you a pint.
I owe you a pint.
Re: Suddenly, MIDI F# 3 wont play in DP 7.24/ RESOLVED!
Bizarrely, the exact same problem happened to me. F#3! It was assigned to Chunk selection for the default sequence "Seq-1". I wonder why we both had problems with the same note? For me, this happened shortly after migrating to a new Mac.
Long standing DP bug. It's bitten a lot of folks (myself included). Truly a mystery his that MIDI command sets itself.
I've been bitten by this as well. I was sure that my keyboard had developed a malfunctioning F#. Hasn't happened for a while, thankfully.
iMac 5k 4.0ghz 32gigs
3 Mac mini slaves
VSL,EastWest Hollywood, LASS, etc.
3 Mac mini slaves
It happened to me years ago and I thought I'd have to buy a new keyboard. Fortunately not.
DP 10.13, OS 13.6, iMac Pro (2017) 3.2 GHz 8-Core, 32 GB RAM, MOTU M4
- daniel.sneed
I've been already got by this one a few times...
Some sort of *assign to command* shortcut I did without noticing, I guess.
dAn Shakin' all over!
DP11.31, OS12.7.5, MacBookPro-i7-3.1Ghz-16GoRam-1ToSSD
Falcon, Kontakt, Ozone, RX, Unisum & Michelangelo, LX480, Sparkverb
