Click is not in sync ..........
For some reason this just started happening. It's about a 32nd note off.......I've trashed prefs, reset my 828Mk3, rebooted everything countless times and still no luck. It's only happening on new projects. I've searched this thread and the manual........no luck. Any ideas would be most appreciated!
2008 Intel G5 2 X 2.8 Quad, 8G RAM, OS 10.9.5, DP 8.07, UAD Quad card, Motu 828 MK 3, Apogee Rosetta 800
Re: Click is not in sync ..........
Look-ahead limiters on Master Buss will mess up click timing.tablehead wrote:For some reason this just started happening. It's about a 32nd note off.......I've trashed prefs, reset my 828Mk3, rebooted everything countless times and still no luck. It's only happening on new projects. I've searched this thread and the manual........no luck. Any ideas would be most appreciated!
Ok.........it is the UAD Precision limiter, but only does it on certain new projects. Thanks for your help!!
You are very welcome.tablehead wrote:Ok.........it is the UAD Precision limiter, but only does it on certain new projects. Thanks for your help!!
Does this have to do with run in real time?
http:www.davidosuna.com
I confess I don't know if I'm "running in real time". I rarely change any preferences, so I am pretty confused why this just started on just a few projects..........I will look into that.
Running in real time is in an arrow drop down menu in the upper right hand corner of the opened plug-in window. It sure messes with my time in my MIDI sequences.
