DP 8 keeps crashing when I edit audios.
I wonder why... Does having interface/not affects the performance?
For now, I don't have an interface.
I need some suggestions on what goes wrong.
Please help,
Vima
DP 8 Crashed when editing audios. What is wrong? Please hel
- supersonic
Re: DP 8 Crashed when editing audios. What is wrong? Please
Does this happen on all Your work drives? Last time I had that it was because of a faulty drive.
Music is movement in silence
What are you doing exactly when it crashes? Editing is a pretty broad description unless you're saying that any operation on an audio file causes a crash. Computer, memory and storage specs help also. Since you do not have an audio device, are you using Windows Audio or ASIO4ALL in your Hardware Config?
DP8.06 PT11.2.0 VEP 5.3.x
Thank you for replying.
I was doing simple audio editing (cutting, trim, fade) 3 second of music and it crashed.
Hmmm, RAM 8GB, Windows 8.
Ow, I remembered I jumped from Reason to DP a couple of time (without slave mode- so work in reason, quit, go to DP)and my sound driver was not found a couple of time, I wonder if thats the case.
- supersonic
It could be. I get that soemtimes wiek going from DP to protools.
