How to record "what you hear" with ultralite
I have two instances of FLstudio playing I want to record them both simaltaneously into wavelab/audition/whatever basically the equivelant of "record what you hear" - how can this be done with the ultralite ? Im using windows 7.
Re: How to record "what you hear" with ultralite
Hi gusss,
The UltraLite-mk3 Hybrid does have a virtual "Return" input that can be used to accomplish this. You can assign this to mirror any output pair on the UltraLite in MOTU Audio Console (check the Return Assign pull-down).
In this case, you can set both FL Studio instances to playback through Main Out 1-2, and set Return Assign to Main Out 1-2 as well. Now, if you choose the Return input in your recording software (Audition, Wavelab etc...) you may record the output from both instances.
Just make sure that you do not set your recording track to also output to Main Out 1-2, otherwise you will get a feedback loop!
For more information, feel free to contact our support directly.
Cheers,
Cheers,
MOTU Tech Support
Please advise all technical inquires should be submitted directly to MOTU's support channels (phone and online support).
