Yes. I'm not sure I understand what you are saying, but if you are trying to say that DP should be able to load a bunch of plugs in a channel strip, Yes, it can do that.askewd wrote: Most people would simply save the whole chain as a channel strip and load it all in one single step. Yes?
New to MachFive3 - some thoughts / questions
- BKK-OZ
Re: New to MachFive3 - some thoughts / questions
Cheers,
BK
- M Kaku
BK
- M Kaku
Well i'm saying that most sequencers work like this these days. I don't use DP i use Logic... but it shouldn't matter. The issues is that if i create a patch in MachFive and modify it and save it as a 'Snapshot' (preset) in logic, it crashes logic when you try to load it back in using the side browser.Yes. I'm not sure I understand what you are saying, but if you are trying to say that DP should be able to load a bunch of plugs in a channel strip, Yes, it can do that.
One person said the answer was simply not to use logics browser... but i don't think burying head in sand is the answer. If MachFive claims it's compatible with logic then the crash issue needs fixing. I'm not saying it's Motu's fault nor Apples - it's obviously just a bug that needs ironing out.
Neither is ignoring the workaround. All you can do is report it to MOTU and hope they address it.askewd wrote:... i don't think burying head in sand is the answer.
I've reported it. Who said anything about ignoring the workaround? Ignoring the "workaround" is the only option i have - the alternative being to willingly crash my machine, lol - now that would warrant one of these.Neither is ignoring the workaround. All you can do is report it to MOTU and hope they address it.
What a warm & welcoming helpful forum...this new Motu customer is really feeling the love from the community....
Sorry if you were offended. I agree, it should work in any app as intended. You might also consider using it outside of your DAW in a bridge such as Plogue Bidule or Jbridge if that helps your workflow any. Yeah, also a major PITA, but I doubt MachFive is due for an update any time soon.
Again, apologies for any hard feelings. No insult was intended. It was more of a reflection of my own frustrations in such situations. Sorry that was not more clearly delineated.
No problem at all Mr. Crisis. Thank you for your human reply it appreciated.
As i have said a few times, i LOVE MachFive3 - i think it deserves more attention and i want to start screaming from the rooftops about it ... but i can't until i know it's stable. I understand that most people on this forum uses DP not logic, and i'm sure it works a lot more stable in DP.
I'll try the official route to Moto and let them know what i've discovered. Hopefully a small update will fix it & all users DP & Logic alike can enjoy the software to it's full potential.
All the best
Dale
All the best
Dale
