DP7 skips after EQ adjustment in BPM
HI, I am new to the forum. I am also new to Motu products. I was very comfortable with PC base Steinburg' DAWs in the 1990s and early 2000 years but stepped away in 2007. I have returned with a Mac book Pro loaded with DP7 and BPM and interfacing with a Motu Traveler. Needless to say I am still in the learning curve with the Software and the hardware. I really like the Motu products and The Mac is great. I do have a reoccurring problem when I make any kind of EQ or FX adjustment in BPM. DP7 Play back will begin to skip every 20 or 30 seconds and the processor peak will indicate for a mili second during that skip. Processor loads stay around 20% except when playback skips. I have repeated this problem a number of times by making a small adjustment to the eq on a kick drum within BPM then testing play back. The result is always the same. Undoing the adjustment will not remove the glitch. Closing and not saving the adjustment to the project will remove the problem. Hope someone has a cure. Hope I didn’t go on to long. Thank you, Dave
