UVI Electro Suite not playing sounds from included synths(ie: UES CarminePoly). It does, however play contructruction kits and such.
The interface of the CrminePoly ( and the others: DirtyMono, DrumShaper, MissionControl, SweepMachine) all come up, but they are empty of parameters. I've scoured the web/UVI and your knowledgebase to no avail.
Help much appreciated.
UVI bank not playing all instruments
6 core machine w 24 gigs RAM using Windows 7 - Assorted Plugs/MachFive/UVI packs/Omnisphere/Komplete 7/etc.
Re: UVI bank not playing all instruments
Not sure if you already have done this but the 3.03 update is required.
Thanks for the reply--but yes, all updated.b-righteous wrote:Not sure if you already have done this but the 3.03 update is required.
I'm stumped. I reinstalled it as well...also; iLok all ok.
Don't have it so it was just a wild guess. Does it work for you in UVI workstation 2.04?
no, same deal, but I can see it loading samples in both (2268/2268).b-righteous wrote:Don't have it so it was just a wild guess. Does it work for you in UVI workstation 2.04?
From the manual of Electro Suite.
It says it requires MachFive 3.1.
Probably soon to be released.
Should work fine in latest UVIWorkstation though.
Try 2.0.5
Try 2.0.5
