What happened to sample rate select in BTD??
- 1176
Hi folks, just making the transition to DP6--so how do you now select the target sample rate in the BTD feature? It is not showing up in the standard menu AFAIK.
- Timeline
Re: What happened to sample rate select in BTD??
Ya happen to look at the controller, rt. side, pulldowns??
- 1176
You mean the sample rate pulldown in the toolbar? Actually I am trying to figure out how DP6 converts sample rate for bounce to disk. I don't see a pulldown for that in the BTD window.
-Will Shanks
2 x 2.26 GHz Quad-Core Intel Xeon
Memory: 6 GB
DP 6.02
MOTU 2408 MkIII, Traveler
Memory: 6 GB
DP 6.02
- kassonica
It's in the same place it always is.1176 wrote:You mean the sample rate pulldown in the toolbar? Actually I am trying to figure out how DP6 converts sample rate for bounce to disk. I don't see a pulldown for that in the BTD window.
Page 952 of the manual
