I hear you. To get the tone I want out of my Marshall I have to crank it a bit. It's not that it lacks gain/distortion... it's hot rodded. But for that gain to actually "clean up" and for the amp to become punchy rather than fuzzy and become an expressive instrument, it has to be loud.Resonant Alien wrote:Purists, don't get me wrong - to a guitarist's ear, nothing can ever match the sound of a real cranked tube amp through a real speaker cab with a real mic. BUT, the Line 6 stuff gets me 90-95% of the way there, and in my situation, I cannot crank my amp loud enough to get the extra 5-10% improvement. Practicality has to intervene at some point.
Also, being in the same room with amp makes a big difference and that doesn't get captured when I record it... not completely. In fact, I find upon listening back to a guitar track, turning it up playback makes it sound better because it's the "moving the air" effect that a guitarist is used to that is missing when listening to a recording.
Additionally however, the POD XT that I own responds differently to touch. Not worse... necessarily... but it just not as "hi-def" as my amp. My amp will spank me if I don't hit a note just right... the POD let's it go. But I have a better range of dyamics and the timbre changes fundamentally over the whole range of soft to loud playing. I haven't been able to dial that in with the POD so much.
I'm also assuming that when I play the stuff I'm recording live, I'll be using my amp and I'd rather develop my technique around amp playing than POD playing. I find in fact that practicing on the POD is useful, but not completely as I have to play differently with my amp, so subtleties of where you can reliably pull out artificial harmonics or whatever you want to call it when you choke up on the pick are different. It's not that I can't get them from the amp, but I have to play it just a bit differently to elicit what I want from the amp. The POD is easier, hence it makes me a little "lazy" when working with my amp and I have to adjust my playing when switching between the two.
