How can DP reduce/eliminate mic hiss ?
I've upgraded my field recording mic to an Audio Technica Pro 24 (stereo condenser, 1/8 " mini plug) and I record onto a Mini Disc (Sharp MT90C). The new mic is producing an audible hiss sound that the old mic (sony stereo) didn't. Is there anyway to clean up the sound in DP. The mic and recorder are not anywhere near other electronic equipment so it shouldn't be picking up electrical interference. Side note: Even with the hiss I'm getting a much better recording with the new mic.
Any suggestions ??
Any suggestions ??
Powerbook G4 1Ghz, 768M Ram, GEM RPG800. For vocal lesson recording: Behringer MXB1002 mixer, 2 x Behringer ECM 8000 omni mics, 2 x Behringer C2 cardiod mics, Edirol R-1. For recital recording: Alesis FireWire Multimix 16, 2 x Studio Projects C3 and an AT835b for vocal focus.
Re: How can DP reduce/eliminate mic hiss ?
Nothing native in DP, but go and get yourself a copy of BIAS Soundsoap - it's only $79 and works like a dream.
Bigger ears hear more, so is the problem really just a side affect of bigger diaphragms?
If you like us tell a friend, if you don't, tell an enemy. www.fingered.net
i'd get a better mic and stop recording to minidisc instead of trying to solve a prolem which has been created by that particular gear combination. past that, waves restoration bundle would work for removing that hiss, but again you would only be tackling the symptoms, not the cause.
pounce : I've just placed an order for the new Edirol R-1 (CF based Wave recorder) so that should take care of the minidisc part of the problem. The microphone was a recent upgrade from my previous mic, should I have picked up a different mic? If so, do you have any recommendations? The mic needs to be suitable for field recording and also be stereo. (Primarily I record Vocal lessons and then edit in DP).
