dirty up vocals
- KarlSutton
dirty up vocals
I've been working on a project & captured very clear, present, vocals. I recorded them with a TLM103 into my ghost with a demeter tube optical compressor lightly compressing it.
I think they sound great, but my client wants them "dirtier" or "grittier" I tried putting the preamp plugin on them & messing with that, he likes it when it breaks up, I however cringe as I tried so hard to get them so clear.
I think if he could have recorded his songs in the 70's on tape through that era of gear that is the sound he's after.
Besides DP's plugs I have wavearts & that's it.
Any suggestions? Thanks!
MPB 17" 2.66 i7/8GB RAM, OSX 10.6.8, DP 7.24, 828 mkII, Ethno 1 via Ultimate Soundbank, MX4, MSI, Komplete 9, Ivory, Stylus RMX.
for a time:MacPro6,1 3Ghz 8 core 32GB RAM
- Dwetmaster
Vintage Warmer is the first thing that popped into my mind as well. Of course, you say you tracked with some compression already so you might end up with other problems with VW.
Maybe try bussing the track to a couple of channels and then mix in a touch of dirt with some of the nasty upper mids notched out and leave your nice pristine vocal full range and front and center.
DP 5.13, Reason 5, Logic 9, Melodyne 3, Live 7, Cubase 4.5, OS 10.5.8 on main desktop, 10.6.3 on laptop. Old analog gear, synths and guitars and heat-belching transformers and tubes.
- kassonica
Copy the track then add the preamp (not to dirty tho but heavily compressed) to the copied track, roll of everything below say 100hz roll off everything above say 3-4kz push the midrange up.
Now bring up the clean Vox track while having the copied track off and slowly bring up the dirty track and blend the two till you get the best of both worlds.
You can also automate this for cleaner verses and dirtier chorus's.
The Massey plugin is a winner and is free as well.
- SixStringGeek
Re: dirty up vocals
Route the track to a set of headphones, clamp the headphones over a mic, record the signal from the mic.KarlSutton wrote:my client wants them "dirtier" or "grittier" I tried putting the preamp plugin on them & messing with that, he likes it when it breaks up, I however cringe as I tried so hard to get them so clear.
Try it when he's not around and see what he says.
Hey, its cheap.
DP 8.newest on MacPro 5,1 Dual Hex 3.33GHz 64G Ram, 3TB SSDs.
- KarlSutton
- daniel.sneed
If you don't get where you want with DP's Preamp, a few more to try :
iZotope vinyl (free)
http://www.izotope.com/products/audio/vinyl/
CamelCrusher (free)
http://www.camelaudio.com/camelcrusher.php
You'll have to tweak to get somewhere, but chances are you'll like it !
CamelCrusher (free)
dAn Shakin' all over!
DP11.31, OS12.7.5, MacBookPro-i7-3.1Ghz-16GoRam-1ToSSD
Falcon, Kontakt, Ozone, RX, Unisum & Michelangelo, LX480, Sparkverb
Oh man, good call Brad; he's one filthy bugger, he is.
Makes George Carlin and Moore/Cook sound like preppies.
- ramadev
I posted this in another thread yesterday:
Wanting a gritty vocal, we ran a mult from the vocal into a miked guitar amp in a tiny bathroom, dialed in a bit of tube distortion on the amp, printed it to a separate track, and mixed a bit of the signal in with the original vocal - it worked great!
Man was I surprised, as I was skeptical at first . . .
Nehalem Dual QuadCore 3.2GHz/8GB/828/MTP AV/10.6.8/DP8.0-DP7.22/Altiverb6.3.5/ChannelStrip2.2.23/T-Racks/AutoTuneEvo/GuitarRig4/Drumagog/bx_XL/FG-X,RC-Tube,VTM/EventideOmnipressor/MelodyneStudio-Cre8 3.2
MacBook Pro Intel Core 2 Duo 2.66GHz/2GB/Traveler/10.6.8/DP8.0-DP7.22/Altiverb6.3.5/ChannelStrip2.2.23/T-Racks/AutoTuneEvo/bx_XL/MelodyneStudio-Cre8 3.2
Neumann,AKG,Earthworks,Soundelux mics/ManleyVoxBox/Avalon737/Amek9098/Genelec1031As
- chunkdz
Try routing the vocal to a stereo bus, then out the analog out on the computer. Plug that into the mini jack input of a memorex microcassette recorder. Playback recorded vocal through a headset mic attached to a Skype phone calling Peru, then have the friend in Peru make an MP3 and send it back to you. Import and phase it in with the original track, and VOILA!
8 Core 2.8
DP 5.1.3
M5 II
DP 5.1.3
M5 II
- Dwetmaster
I'd like to have an apple pie with that?chunkdz wrote:Try routing the vocal to a stereo bus, then out the analog out on the computer. Plug that into the mini jack input of a memorex microcassette recorder. Playback recorded vocal through a headset mic attached to a Skype phone calling Peru, then have the friend in Peru make an MP3 and send it back to you. Import and phase it in with the original track, and VOILA!
- ramadev
LOL!chunkdz wrote:Try routing the vocal to a stereo bus, then out the analog out on the computer. Plug that into the mini jack input of a memorex microcassette recorder. Playback recorded vocal through a headset mic attached to a Skype phone calling Peru, then have the friend in Peru make an MP3 and send it back to you. Import and phase it in with the original track, and VOILA!
You could always rub some coarse sandpaper on the mic while tracking.
