The free VI's/plugs list.
Hey, J.
Adriano posted this one on page 2 (6th post from top).
http://www.motunation.com/forum/viewtop ... c&start=15
I've always thought of this one as "standout value".
Thanks, mate.
MM
Thanks, mate.
MM
Here we go:
Audio Unit - Diatonic Shifter
http://www.ffnn.nl/pages/projects/audio ... hifter.php
Model 1.1 AU
http://www.macmusic.org/software/versio ... n/id/5916/
Model 1.1 AU
Always thought MDA plugs were for VST. Now they have AU plugs. Detune is great for lead guitars and a Leslie emulator is always cool.
http://www.mda-vst.com/
Some have mentioned http://www.soundhack.com/freeware.php already, but I downloaded the bundle for the "compander". I've always wanted to have a compansion plug (after learning about Dolby NR used in tape recording). I haven't messed with it much yet, but hopefully its decent.
- vier-personen
Warp Drive - AU, Universal Binary
http://www.cs.camosun.bc.ca/~c0262447/software/
2 parameters: saturation & volume
from the website:
"Distortion That's Out Of This World!
Tired of using the same old distortion plugins? Check out Warp Drive AU. It's an Audio Unit which is based on a completely non-conventional distortion algorithm."
from the website:
- toodamnhip
I need help. I cannot get color tone to install properly, the installer fails, I have tried everything and a mix depends on it as it was used before my sys got corrupted. Now I need to re-install.bhagert wrote:http://www.tritonedigital.com/
ColorTone Free and PhaseTone
http://www.izotope.com/
iZotope Vinyl
http://plasq.com/musolomo
Musolomo
http://www.solid-state-logic.com/store/
LMC-1 Plug-In FREE
And here is a list of free plugs.
Can someone arrange to e mail me the plugs after installing them, just e mailing me the plgus themselves so I can bypass the screwed up install problem?
Thanks so much
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
- vier-personen
toodamnhip wrote:I need help. I cannot get color tone to install properly, the installer fails, I have tried everything and a mix depends on it as it was used before my sys got corrupted. Now I need to re-install.bhagert wrote:http://www.tritonedigital.com/
Thanks so much
I couldn‘t install them myself till I realized they aren‘t UB yet. But I see you‘re on a G5, so this shouldn‘t be the problem.
have you installed the latest pluggo runtime?
- toodamnhip
Yesvier-personen wrote:toodamnhip wrote:I need help. I cannot get color tone to install properly, the installer fails, I have tried everything and a mix depends on it as it was used before my sys got corrupted. Now I need to re-install.bhagert wrote:http://www.tritonedigital.com/
Thanks so much
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
- vier-personen
well then I am afraid I can‘t help you, although I would like too.toodamnhip wrote:Yesvier-personen wrote:toodamnhip wrote:I need help. I cannot get color tone to install properly, the installer fails, I have tried everything and a mix depends on it as it was used before my sys got corrupted. Now I need to re-install.
Thanks so much
- chamelion
Excellent noise reduction
Hi all,
This little gem has saved my worthless hide on more than one occasion:
http://audacity.sourceforge.net/
http://www.networkworld.com/community/?q=node/2300
Audacity is a free audio editor and recorder, one of its features being noise reduction. More and more, I'm tending to prefer Audacity over Soundsoap 2. As an experiment I turned on the airconditioner and a fan to generate some background noise. I then recorded a test vocal track right there in the middle of the studio, and of course the track was unuseable. I then processed it through Audacity's noise reduction, and it came out as clean as a whistle. Yesssss! I'd be interested to hear other comments and opinions about Audacity. (I haven't yet used it for anything other than noise reduction).
Cheers,
Geoff
Cheers,
Geoff
"Don't worry,
be hoppy!"
be hoppy!"
- mikebeckmotu
Gee, thank you Mike.
Every 9/11 (my birthday), my heart goes out to the US.
Actually, it starts several weeks prior.
It hit me (I watched it in real-time from the word go) as hard as any yank (Aussie term of endearment) who didn't lose family in the tragedy, I can tell you.
Your sentiment means an awful lot to me, Mike.
I'm sure Geoff also would appreciate your yearly gesture.
Good on ya, mate, and thank you!
Monkey D. Under
Monkey D. Under
Maybe I should have gone through the entire thread to make sure this wasn't mentioned already, but here's an "updated" list (at least at the time of publication) of 100 of the best free plugins from createdigitalmusic.com
http://createdigitalmusic.com/2006/11/3 ... -add-host/
6,1 MacPro, 96GB RAM, macOS Monterey 12.7, macOS 10.14, DP9.52
Thanks Hobby.
I got so excited I almost jumped out of my fur, then I realised they're all for Windoze.
Is this one of those embarrassing surprises you spoke of in another thread?
It's difficult to imagine a fallen hobbit, so I hope the remaining revelations are equally as benign...
Your perpetually-confused, furry pal.
Monkey von Skunky
Monkey von Skunky
