moving beat markers to reflect a realtime performance?
Posted: Fri Feb 10, 2006 10:24 pm
Hi all --
This is kind of a newbie question, but I can't seem to figure it out -- I recorded a MIDI performance (ignoring the MIDI tempo) of a song that i want to use as a sort of conductor track, so now i want to basically move the beat markers around and have DP calculate the resulting tempo changes. So 2 questions --
1) I was in the sequence view, and i went to Project > Modify Conductor Track > Adjust Beats , which brought up a window where i checked "drag beats in graphic editor" and "preserve realtime performance" and set the Adjust parameter to "beats". Then I would go back to the graphic editor and try to drag the beats up top above the conductor track (where the play marker usually goes), but every time i would click there, i'd get a message that said "The sequence must be in conductor track mode to adjust beats. To change this, play enable the sequence and use the 'tempo control' popup to switch modes." Well, to the best of my understanding, the sequence is already play enabled, and i can't find the "tempo control popup" anywhere. How do I switch modes?
2) Is there a better way to achieve this?
Thanks in advance all you smart people!
