preferences
scott dansby
preferences
Post by scott dansby »
I recently had a problem with a plugin that effected the whole dp 4.6 program. I called tech support and they had me dump my preferences. Now dp is not running as I would like. What should I do to find my old preferences or which are preferences that I should have and which do I not need?
Thank You
a_real_mf
Post by a_real_mf »
unless you had your old prefs saved somewhere (pre troubled plug in),which is a good idea anyway, you will have to recreate your personlization again..
mf
a real "mf" production
http://www.arealmf.com
scott dansby
No I didn't save them. It is unfortunate so now I will try to regain what I had. I have been successful at repairing one of the problems that I am having is resetting the time signiture to the one I like. I can not find where I do this. Any suggestions.
a_real_mf
Post by a_real_mf »
manual p 570
scott dansby
I have the 4.5 manual and the information is not listed on that page. P 570 deals with time changes.
chamelion
Post by chamelion »
Have you tried enterinhg the time signature you want in the conductor track?
"Don't worry,
be hoppy!"
a_real_mf
Post by a_real_mf »
scott dansby wrote:No I didn't save them. It is unfortunate so now I will try to regain what I had. I have been successful at repairing one of the problems that I am having is resetting the time signiture to the one I like. I can not find where I do this. Any suggestions.
did you not ask about time signature?
ie meter change ?
scott dansby
Yes I have. The problem is not changing it but saving it when I go back in after closing dp down and the time signature that I like has reverted back to the one I do not care for.
a_real_mf
Post by a_real_mf »
scott dansby wrote:Yes I have. The problem is not changing it but saving it when I go back in after closing dp down and the time signature that I like has reverted back to the one I do not care for.
hi please xplain...what is the time sig you care for?
and have you tried making the time sig you care for a default template? (page 8 )
