I need a remote recording medium . . . I was considering getting a Masterlink, but then I'm obviously limited to 2 tracks.
Now that the iMac G5s are down to $1200 or so, I am considering getting one of these as a remote "recorder" to use with my 828 mkII. The problem is it only has one internal drive. If I bought an external firewire drive (for the audio data), would recording through the FW bus and printing to a HD on the same bus create throughput problems. The most I would do would be 16 tracks at once. Most guys do this with a Powerbook, but it seems silly with the horsepower to price ratio with the iMac G5 (and though it's bigger than a laptop, its very portable.)
Thoughts?
Thanks,
Mike
Firewire Throughput
I have worked with people who have done this successfully with a Powerbook, so I can't imagine it being an issue. However, the hard drive in your iMac will be a 7200 RPM drive, so it would be plenty fast enough to record on. I know it's not cool to record on your internal drive, but when you're just using this for field recording, why not?
Logic 8, Dual 1.8GHz G5, 2GB RAM, 2X UAD1, AutoTune 4, 896HD and OctoPre, MIDI Express 128
