Importing audio from Garageband
Hi, I am trying to import tracks from GarageBand into DP 4.61. I lock (freeze) a track in GarageBand, then go to the song file, show package contents, and copy the .aif file of the track to the desktop. Importing into DP (via drag and drop, or the Import menu), does not work. Don't quite understand why, it's a regular .aif file, and I have read and write permissions. Any ideas?
Thanks,
Frank
Thanks,
Frank
Yes, tried both the Tracks and the Soundbites window, and the Import menu in the main menu and the Soundbites mini menu (which seem to be the same).
The .aif file is not greyed out when I use the Import menu, but when I select it, it does not show up in the small preview window, so the 'Add' button is not active.
Frank
Frank
Dragging AppleLoops into the soundbite window works, but this is not what I'm trying to do - I'm trying to import an .aif file that was extracted from the package of a GarageBand song file - not a loop, but something I recorded, put effects on and froze (locked).
The AppleLoops look exactly the same as the file I'm trying to import - same icon, .aif file. Don't know why it works for the loop, but not for the file I took from the package.
The DP project is set to 16bit/44.1k, so that's not the problem...
Frank
Frank
For the record, I compared the loop and the extracted .aif files with XRay and FileXaminer, to see if there are any differences in obscure permissions etc, to no avail.
I went the 'export each single track to iTunes, then import to DP' route that I wanted to avoid - clumsy...
I guess even as a sketch book for quickly taking down a few tracks GarageBand is not such a good idea
- giles117
The issue is Garageband and Logic Frozen audio files are in a 32 bit Floating Point format and you need to convert the format to something DP will read. Like 24/48 SDII Format.
I Use Barbabatch to convert all my Logic/Garageband Frozen Audio Track Files to SDII (DP's native) format....
Also as the previous poster stated, using itunes is a cheaper route. Convert the files to AIFF with itunes works wonderfully....
DP 6.02
Quad 3.0 Ghz, 8.0 GB RAM, 2 - 1TB HD, 5 - 500GB HD's (RAID)
MOTU HD192, 2408mk3, Microlite, UAD-1, UAD-2, Powercore, Lavry Blue AD/DA convertor, LA-610
Euphonix MC Control
29 years in this business and counting.....Loving every minute of it.....
Euphonix MC Control
This is a free plug in that allows you to stream GB into DP and record it live. I got it to work once, but it's really easy to get confused. At least for a guy like me.
http://www.jackosx.com
"Give a man a fish and he will eat for a day. Teach a man to fish and he will wipe out an entire species."
DSP-Quattro imports just about everything float 32bit etc etc. Its on sale @50% off through today!!. I got mines!!
http://www.i3net.it/Products/dspQuattro ... anguage=EN
How do you extract the file GB? Does it have to be the whole tune or can you extract just one tracK?
T
T
Single tracks. What I was trying to do was to go to the GarageBand song file, which is a package, show the package contents, copy .aif files to the desktop, and then import them into GarageBand. Didn't work, see giles117's explanation.
Soloing each track and then exporting it into iTunes as a song worked.
Thanks to everybody for the helpful comments!!
Frank
Frank
Hi giles117,giles117 wrote:The issue is Garageband and Logic Frozen audio files are in a 32 bit Floating Point format and you need to convert the format to something DP will read. Like 24/48 SDII Format.
Thanks for sharing knowledge... though I was aware of that issue as I've tried to convert some IRs in WAV format to deinterleaved SDII via DP drag&drop facility and wasn't able because of the 32-bit sample format, so I ended up doing it first in LIVE (32-bit > 24-bit) cause I didn't own DSP Q at that time (bought it just yesterday...) and finally being able to import the files in DP.
Here's my question : as I haven't seen this option available both in LIVE & DSP Q manual, I wondered if there is any *invisible* dithering applied by default to resulting files when converting sample format from 32-bit (float or integer, what the difference..?) to 24-bit ?
Or is it just unnecessary & only requested for final pre-masters from 24 to 16-bit !?
Thanks a lot in advance.
