DP4 is just unreliable. What's going on here?
DP4.12 with OSX (and Protools 6 and Roxio Toast, Jam 6 for that matter) is quite unreliable. It can record 44 tracks for 4 hours one minute, and crash recording just 2 tracks the next. DP3 with OS9 is rock solid with absolutely no exceptions (yes, I've switched back; no, the problem is NOT hardware related; yes, I know how to set my buffers, etc). My pattern recognition skills are telling me the real problem is that OSX is simply a bug riddled mess but any insight would be greatly appreciated.
I'd like to know if anyone else has seen this behavior. I do NOT know all the answers to anything.[/quotejimfisheye wrote:Aramis wrote:If you know all the answers why do you ask ????
Ok What I mean is , you are not specific '
A lot of problems mean ram problems and hard disk problem and bad habits in software load problems ....
There is a way to troubleshoot problems ....
Aramis
iMac 2012 27 ' 3.2 ghz 32 gigs ram OSX 10.9.4 DigitalPerformer 8.7 , MOTU Track 16, MOTU MachFive3.2, Ethno and BPM , Komplete 9, OmniSphere , Trilian and Stylus RMX , Axon mkII and Godin LG .
A lot of people are using DP in OSX without problems. I understand the frustrations when you're having crash problems - I was there for a long time until I tracked down a bad stick of RAM. I have no problems whatsoever now and DP runs solidly in both 4.5 and 4.61. Nine times out of ten it's something in your system when you're getting random crash behaviour.
Agreed. But the thing is I can load the OS 9 system and beat up on it for 2 weeks with absolutely no problems. If I load the OSX system I'll have a crash within 3 days. I've done a lot of testing over the last month including repeatedly running Apple hardware tests. Am I missing something?dmshep wrote:A lot of people are using DP in OSX without problems. I understand the frustrations when you're having crash problems - I was there for a long time until I tracked down a bad stick of RAM. I have no problems whatsoever now and DP runs solidly in both 4.5 and 4.61. Nine times out of ten it's something in your system when you're getting random crash behaviour.
I should add that these experiments are being run on 2 different computers with the same results. (Two 667 TiBooks w/ 768M ram)
The best way to get help here is to post some specifics - your set-up (hardware and software), versions of software and drivers, the kind of crash you're experiencing (does it freeze up? Hang? Suddenly shut down? Are you getting crash reports?), whether it happens with any other apps, etc.
Have you removed the iSight plug-in? It's known to cause conflicts with DP. There are threads around here that go through a lot of possibilities if you run a search. Like this one:
http://www.motunation.com/forum/viewtop ... ght=isight
or this one:
or this one:
Again, I know it's frustrating, but it can be sorted out. Run some searches, and post your set-up.
or this one:
or this one:
TiBook 667 w/ 768M ramAramis wrote:Please reply with your setup ????
OS 10.3.9
DP 4.12
60G 7200 rpm 8M buffer Hitachi internal HD
120G 7200 rpm 8M buffer WD external firewire HD
I get the least amount of crashes with the buffers set to stupid big numbers: buffer size 1024, disk read/write 1000k, buffer per voice 2,000,000 samples.
Possible clue: setting the host buffer multiplier to anything but 1 produces constant glitches in the audio. The red light will be flashing on the CPU meter even though the meter is hovering around 20%.
This setup is for recording only. (Live remote recording where there can be no glitches.) ProTools on a different system is used for post production.
Just read all the posts about the iSight plugin. My system doesn't freeze or quit. I'll get the "HD can't keep up error" (again, sometimes when only recording two tracks). The performance meters are floating around 10 - 20%. When the error happens the disc meter IS pegged (ie. instantly goes from around 20% to pegged). This would SEEM to indicate HD trouble but again - with 2 tracks?; and this NEVER happens with DP3 in OS9. (Sure, I can set buffers too small and force this to happen, but never with the proper settings). I should add that the HD is defragmented with over 50G free space (the internal) or completely emply (the externals).
Yes. When I set up the HD Disk Utility wouldn't let me select extended without journaling. I guess I just assumed that's the way things were now with OSX and ignored it (now that sounds kind of stupid of me).TheHopiWay wrote:You don't have journaling enabled on any of your drives do you?
Strange - the "disable journaling" command Apple talks about in disk utility doesn't seem to exist. TechTool has this ability though.
Is journaling a huge resource hog?
I'll post if this cures the problem.
Makes sense yes but Activity monitor tells me I've got plenty of headroom left even when throwing 40 tracks down. Since these two machines only record, I'll never need the processing for mixing.westla wrote:Here's a wild guess .... you need more RAM.
OSX needs much more RAM than OS9.
Also that is a pretty slow processor in your computer. Dosen't it make sense that a OS that is 6 years old would require less resources than a new OS?
