disk defrag software, Is nortons utlilities still the one?
mbmusic
Post by mbmusic »
I just upgraded to 10.3.9 dp 4.6.
what is the best drive defrag software?
thanks mbmusic
Mac Pro 2.66, 3gig ram, HD192, 2408 mkII, DP 5.12, MTP AV, UAD-1 Studio Pak, Avalon 737, TLM 103, AEA R84, Great River MP2, Presonus M80, Roland xv5080, Pod Pro, EZdrummer, Ozone 3,
Many Lacie 160 gig external drives,
Schweats
Post by Schweats »
I'd highly recommend Alsoft's Diskwarrior•„•
alsoft.com••¦ probably no better directory rebuider
Schweats
MacPro 2.8/OS 10.10.1/6g ram/Powerbook G4/1g ram/10.4.11/828 mk3 hybrid/MTP AV usb/DP 7.23/Stylus RMX/Omnisphere/Trilian/Mach Five v2/RealGuitar/Korg Oasys/UAD2-Quad card & various plugs/Novation Zero SL mk2 controller/Akai MPK61
Guitar Gaz
Post by Guitar Gaz »
I still use Norton's and it works fine for me - you occasionally have to load an update from their site. But it all seems to work with Panther - I presume its okay with Tiger. I have heard good things about DiskWarrior but I am used to the Norton way - and have used it for more than 10 years. The deleted file retrieve is very good too.......
Gary Shepherd
____________
dixiechicken
Post by dixiechicken »
ABSOLUTELY NOT!
Use Norton at your own risk. You are courting disaster.
1)
Alsofts Diskwarrior DOES NOT defragment files on your harddrive.
2)
DW analyzes your folder structure and reconstructs a new one -
3)
Allows you to compare the new folder structure with the old one
4)
And if you want to do so - you can choose to replace the old folder structure
with the new folder structure.
5)
B.t.w you DONT need Disk Warrior for this. You can boot up OS-X in
"Single User Mode" and at the black terminal command prompt do the
exact same reconstruction much faster then DW.
IF you need to defrag your files get Techtool Pro 4.x.x from:
http://www.micromat.com/
This tool allows to do both defragmentation and rebuilding of folder structure as well as doing hardware tests.
You should install the eDisk partition from the Techtool cd to get another boot partition with only system OS-X + Techtool on it.
When you need to check your other drives/partitions - boot on the eDisk
an run Techtool from this partition - much faster than running it from the CD itself.
However this benefit is maybe countered somewhat by the fact - IF you
install the eDisk partition - you will in normal computer use have a
"Techtool" process running in the background that consumes cpu cycles
as well as some memory.
Under no circumstances should you use Norton "Utils" under OS-X.
Cheers: Dixiechicken
My God it's full of stars....
Mac Pro 6-Core Intel Nehalem/Xeon 2.93 GHz 32-GB ram, OS-X 10.13.5-Swe, DP-9.52, Unisyn-2.11, 828-MkII,MTP-AV usb, Latest drvs, Wavearts plugs, Kurzweil-2000, Proteus-2000, EPS-16, Pod-II,
Digitech RP-155, Soundcraft UI-16, Emes Kobalt monitors.
TheHopiWay
Post by TheHopiWay »
dixiechicken wrote:ABSOLUTELY NOT!
Use Norton at your own risk. You are courting disaster. ..................... Under no circumstances should you use Norton "Utils" under OS-X.
Issues?
RJ Wade Music
Post by RJ Wade Music »
[quote="dixiechicken"]ABSOLUTELY NOT!
Hi All,
I've been using Norton for Panther 10.3.9 and prior to moving to OSX and I NEVER had a problem. I have, while on a gig in Cali, used DW at the request of another producer. However it was simply to optimize the directories and file structures. I ALWAYS use Norton for Optimizing.
I will agree that TechTool is also a very useful tool for other system operations that Norton.
...........Just my humble opinion.
RJ
RJ Wade Music, Inc.
Songwriting/Programming/Engineering
MacBook 2 GHz Intel Core 2 Duo 2, 4GB Ram, 80GB Internal Drive, Mac OS 10.7.5
MOTU 828mkII Audio / MIDI Interface
Glyph GT050 120GB FW
Glyph GT050Q 250GB, FW 400/800, eSATA, USB2
MOTU Digital Performer 7.24
Machfive 3.0
Melodyne Editor 1.1.5
Waves GOLD V8
BIAS Peak 6.2
Mackie HR 824 mk2
M-Audio Keystation 61es
bongo_x
Post by bongo_x »
dixiechicken wrote:
5)
uh, OK. and what is that, exactly? I'm not sure I believe this, but this information doesn't really say anything without the actual command.
Billy
Guitar Gaz
ABSOLUTELY NOT!
This is the sort of ill-informed crap that really annoys me - just sheer ignorance I'm afraid which might put some people off Norton which is a shame. What disaster exactly ? I've used Norton all through OS8, OS9, and now OSX without problems. Sorry but you should not be giving out such misinformation.
Gary Shepherd
____________
RCory
Post by RCory »
I was under the impression that Norton has dropped continuing Mac development. This wouldn't be a good thing and I wouldn't trust my Mac to them. Besides, Norton is always calling home for updates and it's an annoying pain.
I've heard some people here swear by Drive Genius. I've been thinking about picking it up since TTP is so slow...
C
RCory
Post by RCory »
Guitar Gaz wrote:ABSOLUTELY NOT!
There's nothing wrong with someone's opinion.
dixiechicken
This topic has been discussed before here on Unicornation.
(and thus should be searchable)
Unless Symantec has been updating Norton Utilities for Mac to be fully
supported under Mac OS-X, I can not recommend anybody to use it.
If I'm not misstaken RCory is right on the money, when stating that
symantec has halted development on Norton Utilities for Mac.
Defragmenting files on a harddrive is a potentially dangerous operation.
Disappearing files and partions, unmountable partitions etc can and will
eventually happen.
I will grant that ones mileage can vary, I have had the above things happen
to me on several occasions running, chkdsk on pc-systems, running Norton
Utils on Mac OS-9 and Mac OS-X and also just recently actually running Techtool Pro on iMac at home for reparing my severely corrupted
boot-volume. Forcing a complete re-install of everything.
I do not however remeber having this happen to me running Partition Magic
on a PC at work.
Guitar Gaz - what I say IS NOT CRAP - I have over 12 years proffessional experience supporting well over 200 computers at our deparment. (mixed environment)
If you as opposed to me - have had the good fortune - to never experience the agony/hassle of trying to restore a system due to a harddrive chrash - you are blessed.
As for booting Mac OS-X into "single user mode" this info can be searched for on the internet . ( dont be so f-g lazy :lol: )
Check out these links:
http://search.info.apple.com/?search=Go ... ser%20mode
http://docs.info.apple.com/article.html ... trtup.html
http://www.macosxhints.com/article.php? ... ry=cmd%2Bs
When are standing at the command prompt you can type:
man fsck [hit enter] for reading up on how to use this utility to rebuild and
check your folder/node stucture.
B.T.W to restart your Mac from the command prompt type:
reboot -. and hit enter.
bongo_x
Post by bongo_x »
I'm no expert but I'm just not sure that fsck does "the exact same reconstruction" as disk warrior. I use fsck all the time, and actually I use applejack to run a bunch of stuff auto from single user mode. applejack is great btw (although friends of mine have had few weird issues like fans sticking on and having to be reset). It just runs the built in unix utilities automatically or however you want.
I don't we need to get too cocky because we know how to type some unix commands ;-) I just think that the built in tools are great but I still think diskwarrior is well worth having and does a great job.
Billy
dixiechicken
There's nothing wrong with using DW if you prefer this method instead of using lovely unix-commands. 8)
I have had DW also thrashing the folder structure beyond repair on my iMac.
Although it have just happened once.
You should consider Techtool and DW tools for us lazy amateurs.
(me included since I use them :wink:)
However making changes in the filesystem on any harddrive any platform -is
a potentially dangerous activity.
If you want to play it safe - make a backup of everything thats important to you-
before you engage in messing around with filesystem tools
Both Techtool and DW should be used on a fairly regular basis before problems with
file corruption - file table inconsistencies etc. has gone too far.
Att http://www.ontrack.com/desktop/ - you can find desciptions on how they work
when restoring data from damaged/chrashed/burnt up/drowned harddrives.
Our fave-tools mantioned above, work well enough most of the time.
Still - they have both damaged systems for me on a number of occasions.
Both TTP & DW are tools supported under Mac OS-X - but using a tool NU that is not -
is not really a best practice.
Guitar Gaz
Umm.. so you don't actually know? Well their web site says it is supporting Tiger now as it was for Panther - version 8.02. I don't know about re-starting a system after a hard drive crash but is that down to Norton? Anyway - it does work and I've not had any problems with de-fragging over many years. Which is mainly what I have used it for. I don't think I'm blessed - it works and thats a fact. For how long they will support it - I don't know - but they are at the moment.
However - the files that get fragmented I regularly copy to my USB and Firewire drives - delete them from my hard drive - then copy them back. This seems to keep the fragmentation down. I keep more of the bulky stuff on my external drives. I then copy one drive to another - then wipe one with Disk Utility, copy the files back then wipe the other and copy back to that drive. That also seems to work. So if you don't think Tech Tool or Disk Warrior do what Norton does and don't want to buy Norton - do this instead. But it helps to have two or more external drives. Also fragging is supposed to be not such a problem as it was under OS8 and 9 - certainly my Mac doesn't get slower like it previous ones used to get.
Gary Shepherd
____________
sdfalk
Post by sdfalk »
