Noise Floor test
Posted: Tue Nov 22, 2005 1:30 pm
Hello:
I have been running some tests on our systems. Specifically, I am running noise floor tests. With the G5 dual 2.0, DP 4.6 and a Motu 24 I/O I am getting a 87db s/n ratio at 24bit / 96khz. Frankly, this seems pretty noisy for a 24 bit A/D. My old Fostex G16 tape machine has 86db s/n with dolby C. The noise is white unlike the traditional 16 bit triangle hash. I performed the test with a grounded input plug and recorded silence. I then put two trim plugs in at +40db each reading the level at the second plugin. It makes me wonder what other A/D boxes have as a noise floor. To say the least, I'm a little disapointed. These are line level inputs which should be giving -120db I would think.
Care to post your noise numbers so I can get an idea of what the norm should be?
